Old 08-03-2009, 10:28 PM   #1
Blue_dragon_192
Drives: 2009 Yaris 4dr Sedan
Question about painting the Engine Cover
A couple of simple questions.
1) How long can I drive my car without the cover on?
Is it just a cosmetic item or does it protect the plug wires and everything there?
2) On the cover where the 4 screws hold the cover in place, the top two holes have Metal retainers with rubber grommets in them. How do you remove them, or is it ok to paint over them.
I am keeping with the Black and Red thread of my interior (BSP paint, Black interior, and RED LED's), with the engine cover (Red cover, Black lettering and Logo).
Let's see how this goes....
Blue.
Blue_dragon_192 is offline   Reply With Quote
Old 08-03-2009, 11:07 PM   #2
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Drives: 2008 Yaris LB
I don't know if it actually protects anything, but I've had mine off since I've had the car which is over a year and never have had any problems. I have no idea how to remove the grommets, though I'm sure it's fine to paint them.
_________________________________________________
Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers
Jeemee is offline   Reply With Quote
Old 08-03-2009, 11:32 PM   #3
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I guess it's there to protect the engine in the event your hood is up and there is precipitation or anything.
Old 08-04-2009, 12:03 AM   #4
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
I wash my engine with the hose and I don't have an engine cover on mine.
Old 08-04-2009, 07:39 AM   #5
Blue_dragon_192
Thanks all.
Now on to getting it prepped and then painted.
Old 08-04-2009, 10:11 AM   #6
Blue_dragon_192
Is it just a cosmetic item or does it protect the plug wires and everything there?forever, just cosmetic...
2) On the cover where the 4 screws hold the cover in place, the top two holes have Metal retainers with rubber grommets in them. How do you remove them, or is it ok to paint over them. You can just pop them out, in the middle they have metal flange you can pry out with a screwdriver, then the rubber will flex and pop out...
Cheers
Thanks echo_hrs!
Old 08-04-2009, 10:13 AM   #7
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
be gentle with the red paint ;) keep it clean!
Originally Posted by xnamerxx
you nailed it sir.
Old 08-05-2009, 10:55 AM   #8
Blue_dragon_192
Tamago, I will be gentle.....It's going to be all red, and the logo and vvi in black.
If not, then sand and paint black again.....
Old 08-05-2009, 10:59 AM   #9
Blue_dragon_192
On to my next questions.
I have sanded the cover and will use a tack cloth to clean it up.
On to the questions.
Where do you find the hi-heat primer and paint (paint I can find, but in black only).
Or can I paint it with regular paint and then use a high heat gloss (clear)?
Old 08-05-2009, 11:15 AM   #10
I painted mine with normal automotive paint. I've done a couple of multi-hour trips without any visible damage or discoloration.
Old 08-05-2009, 11:55 AM   #11
Blue_dragon_192
Thanks CTScott!!!!!
Old 08-05-2009, 12:45 PM   #12
Bob Dog
DARK PHASE OF THE MOON
Bob Dog's Avatar
Drives: 07 liftback
You might condsider an engine or exhaust pait as they are sticky, heat resistant, and tolerant of petrochemicals
Bob Dog is offline   Reply With Quote
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
Engine cover for S/C engine LtNoogie Cosmetic Modifications (Exterior/Interior) 84 05-04-2009 08:41 PM
FS: OEM Engine cover kustom play Items for Sale by private party 0 03-21-2009 08:59 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
