11-25-2009, 07:37 AM | #1 |
help help help big problem no brake lights
hi all i just got a set of jdm RS lights and i did the diy but am having problems and i ned to know what color wire from the Australian yaris to the jap rs lights ... i cant fined anything :( its 11:30 and i need to go to work at 7 :( cany anybody help me : confused:
11-25-2009, 11:05 AM | #2 |
Drives: 2009 Base Hatch 2 Dr Auto Join Date: Dec 2008
If you installed some sort of aftermarket kit remove it and you lights should work again.
11-25-2009, 03:26 PM | #3 |
they are jen toyota rs lights
11-25-2009, 03:56 PM | #4 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Are they the ones with the LED stop lights?
If so: Right side: Orange - Stop Grey - Tail Yellow - Turn Signal White w/black - Ground Left Side: Violet - Stop Green - Tail Light Green - Turn Signal White w/black - Ground |
11-25-2009, 03:59 PM | #5 |
Here You go , but remember this is for US cars
so there drivers side is our passengers side . http://www.yarisworld.com/forums/sho...t=22593&page=3 |
11-25-2009, 09:02 PM | #6 |
ok thanks guys it seams that there may be a fuse blown as i have been fiddlying with it and on my way to work everytime i had to slow down i had to flick my lights on so i am searching for the brake light fuse ???
11-26-2009, 12:20 AM | #7 |
passengers side , under the glove box from memory
11-26-2009, 12:24 AM | #8 | |
Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
sometimes if you have to cut the wires and re-connect them they dont make good contact, try to rewire that particular set of wires....especially if all the others are working fine......
or try the fuse....dont see why a fuse would have blown if your battery was off? :(
-Jen <3 Quote:
11-26-2009, 12:47 AM | #9 |
Drives: Yaris 3dr Hatch/Black Join Date: Feb 2006
The only wreck I've had in 25 years was in rush hour and the clown in front of me had no brake lights. IT DOES MAKE A DIFF.
He was driving a pickup truck with trailer hitch and a dangling connector. Apparently it wasn't wired right. After that I notice about 60% of trucks with trailer hitches and dangling connectors didn't have brake lights. Lots of incompetent electrical guys about. |
11-26-2009, 05:25 AM | #10 |
all good guys it was a blown fuse... what i did was pulled the lights plug apart and coved the needle side in heat shrink and pluged in the light so i didn't have to brake my car plug ... any way to pins were touching and had blown the fuse son the brake lights had gorn out all is good now though thanks to CTScott, 1NZYaris1 & YAR1S onya guys thankyou very much and good story woof
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Problem removing front brake rotor | jkuchta | DIY / Maintenance / Service | 24 | 02-27-2016 09:41 PM |
Re-did lights, fixed scratch, RR floor mats! lots-o-pics | dg4rez | Photo-Video-Media Gallery | 15 | 04-21-2009 01:45 AM |
big brake kit | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-13-2007 01:44 PM |
big brake kit | yrsdrgn | Performance Modifications | 17 | 02-20-2007 11:05 PM |
cheap trd big brake kit *joke* | birdy | Off-topic / Other Cars / Everything else Discussions | 3 | 06-13-2006 12:04 AM |
