Old 09-29-2011, 02:07 AM   #1
bankrobber
Drives: 2007 Yaris Hatchback
gears grinding
A few times I was sitting at a Red light and when it turned Green I pushed clutch real fast and put in 1st gear but it grinds the gears if I do it really fast. I didn't notice this before. If I push clutch and give it a second before putting in gear it wont grind. Is the synchronizers wearing out? I change fluid about every 30k with synthetic blend from walmart. I got 121k miles on car.
bankrobber is offline   Reply With Quote
Old 09-29-2011, 11:40 AM   #2
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
i get the same thing, although I notice it more often since I changed to royal purple gear oil. I'm also getting a grind when I go from 2nd to 3rd quickly if I don't double clutch.
-Type 07 FFL-
My odometer 03/11
Old 09-29-2011, 04:32 PM   #3
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
^^ Yep same here !!! Switched to royal purple a few months ago and have very notchy engagement and a desent grind when going 3-2 . I think its just to slick for the yaris gears imo .I will be switching to redline mt-90 next weekend and hope that helps...
Old 09-29-2011, 08:00 PM   #4
jekqmb
Local Sh*t Disturber
Drives: 2009 Yaris LB
I got the same problem fron 3rd-2nd..... Does it quite often!
Old 09-29-2011, 08:13 PM   #5
ecc_33
ecc_33's Avatar
Drives: 2008 toyota yaris
Yeah, i switched to royal puckal at 55,000 and hate it.....I got MT 90 on the shelf for the 70,000 mile oil change coming up....I just shift nice and soft/smooth for now.....I got 65,000 on the car and mine doesn't grind into gears.
08 toyota yaris with some big tires lol
02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
ecc_33 is offline   Reply With Quote
Old 09-30-2011, 09:49 AM   #6
bankrobber
hmm, I have had the same kind of oil in for 2 years so cant say that is why. Guess I cant try to pop it into gear so fast.
Old 09-30-2011, 10:05 AM   #7
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
only time I ever had an issue with grinding a gear when shifting is when I didnt push the clutch far enough and i was shifting faster then usuall. My hands were moving faster then my feet were. but under normal driving I never had a problem with this. I did notice you guys are running Higher milage then me and you guys gots 07-08s.. maybe '10 got some improvements or its just not worn in yet
-Derrick-
Old 10-01-2011, 01:55 AM   #8
bankrobber
Starting to happen more frequently think 1st syncro is getting bad. Better change oil to see how it looks
Old 10-01-2011, 01:57 AM   #9
bankrobber
Feel like I am driving a dump truck again
Grinding noise in reverse NickNickNick DIY / Maintenance / Service 14 03-15-2013 03:10 AM
Grinding noise when switchingfrom second to third gear Stiv DIY / Maintenance / Service 2 01-04-2011 04:35 PM
yaris 2009 MMT-problem in shifting gears. matanfr DIY / Maintenance / Service 8 06-30-2010 01:37 AM
Stiff gears after a while juxtapozed General Yaris / Vitz Discussion 10 05-05-2010 04:37 PM
2004 yaris hatch, 2nz-fe, DFCO in all gears? toyo Fuel Economy Forum 11 06-26-2009 02:21 PM
