Old 12-06-2012, 12:15 AM   #1
yariseggvvti
Drives: Yaris Hatchieback
Idle low
When I come to complete stop, My idle is low and vehicle is shake a bit.
Then I shift in to neutral, the vehicle is okay.
Air flow meter problem or something else?
I replace it about 20k ago.
Any idea and appreciated advice!
yariseggvvti is offline   Reply With Quote
Old 12-06-2012, 08:21 AM   #2
Try cleaning the throttle body.
Old 12-06-2012, 10:26 PM   #3
yariseggvvti
any suggestion? Thanks!
Old 12-06-2012, 10:52 PM   #4
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Old 12-06-2012, 11:14 PM   #5
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Seafoam it, or take it apart and clean it.
Old 12-06-2012, 11:27 PM   #6
caineroad
caineroad's Avatar
does seafoam really a help or just a myth?
Old 12-06-2012, 11:33 PM   #7
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Seafoam is effectively a strong solvent, which at the very least, will take some grime out of the engine.
Old 12-15-2012, 05:21 AM   #8
dindy
metallic green vitos
Drives: 2002 toyota vitz. 1.0 auto
Send a message via MSN to dindy
becareful cleaning the throttle body!!! i did the same thing and...wallllaa!!!! 500 euros of damge!!! i was too idiot to use wd-40 to cleaning it. results--- damaged afm and throttle position sensor.....changed them. car it is ok few few weeks, but later i experienced high idle!!!! i checked on internet. found out to clean my idle control valve....i used throotle cleaner....result was epic!!! more high idle about 4000 rpm!!!!! 250 euros on idle control valve - 90 for afm - and 70 euros on tps......plus mechanic labour. ct scott told me to NOT USE wd 40 or something similar in this sensors. he was right!!! i know a friend who damaged the alternator with wd 40 u similar too! becareful with these solvents, sorry for typing too long about this, but i dont want some people to pass this shit experience like me. after all, still i got little rough idle...but it drives perfect!! (note all sensors are from original toyota parts)
dindy is offline   Reply With Quote
Old 12-15-2012, 03:28 PM   #9
nookandcrannycar
Originally Posted by caineroad View Post
Even though the difference doesn't seem to jive re time zone difference (which I've found isn't always accurate on Yarisworld), I have a feeling that in real time yariseggvvti's post = only 5 minutes after CTScott's, so he was likely typing his post when CTScott posted.
Old 12-15-2012, 03:49 PM   #10
caineroad
caineroad's Avatar
of cos not, the time is reflected differently on each account, but the time system is always constant. He posted 14 hrs afterwards.
PS: don't go off topic
Old 12-15-2012, 03:52 PM   #11
caineroad
caineroad's Avatar
should have followed instructions on here or micro image... or at least find more info on the internet first before attempting this. Only TB cleaner is to be used to clean TB, although carb cleaner also works but some say it damages gasket.
Old 12-15-2012, 06:00 PM   #12
nookandcrannycar
You're right, I missed the AM/PM difference. The rest of that assertion, maybe (not really worth more analysis as the AM/PM miss makes me wrong anyway). He should have noticed CTScott's post, but I think he just posted without 'catching up' re reading the thread. I don't think he meant any disrespect to CTScott (and I'm not saying you think he did). Also, my post wasn't any more off topic than your question mark.
Old 12-15-2012, 06:03 PM   #13
caineroad
caineroad's Avatar
what the heck? find better things to do in your life than analyzing this. I am not responding to you anymore.
You've gone off topic again.
Old 12-15-2012, 06:06 PM   #14
nookandcrannycar
......ever heard of projection .
Old 12-17-2012, 12:04 PM   #15
dindy
i heard about throotle body cleaner, but on other forms told me to dont mess sensors with him.
Low RPM when Idle Betrivent DIY / Maintenance / Service 12 03-03-2013 06:55 PM
Very Low IDLE charlieXX Middle East 24 11-03-2011 06:00 AM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 08:23 AM
Low idle speed gonzo452001 DIY / Maintenance / Service 9 02-21-2007 08:41 PM
