Old 03-14-2014, 12:34 AM   #1
kropekoi
Drives: vios 1.3J
2" drop, need camber?
Hi All!
I just got a new set of lowering springs, 2" drop.
My wheels are 17x7.5 Keiichi Tsuchiya Mags DTM, not sure the offset though
Do I still need a camber kit?
kropekoi is offline   Reply With Quote
Old 03-14-2014, 03:21 AM   #2
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
No :) You'll get a nice tight fit! Also depends on the tyres you have.
Speedbumps suck...!
G-Ammo is offline   Reply With Quote
Old 03-14-2014, 03:43 PM   #3
If you are asking because you have some rubbing, can't say without knowing the offset and tire size.
Is some other reason you're asking?
Old 03-16-2014, 04:23 AM   #4
kropekoi
Drives: vios 1.3J
Not really sure about the offset, 40-45? Tires 205/40/17
Old 03-16-2014, 10:39 AM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
how much room is there between the back of the tire and the strut?
Old 03-17-2014, 12:13 AM   #6
kropekoi
Drives: vios 1.3J
not experiencing some rubbings yet, but, the gap between the tire and the fender is 2 fingers, my mechanic says that it will get lower and lower in time since its just a fresh install of the springs....
Old 03-17-2014, 05:28 PM   #7
G-Ammo
G-Ammo's Avatar
True.. but itll lower about 1 cm max :) not more... so you'll really have a nice fit! if you have rubbing inside the fenders... u might get some spacers (if you rub when steering)
Speedbumps suck...!
Old 03-17-2014, 10:58 PM   #8
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
You shouldn't need camber for 2"
Originally Posted by sw07gt
Old 03-20-2014, 09:12 AM   #9
kropekoi
Drives: vios 1.3J
thanks all!
Old 03-20-2014, 09:51 PM   #10
Springs will settle 1/8" to 1/4" but only in the first week or two. After that, they will stay the same height for the life of the spring. Especially if you bought a good quality, brand name spring.
Old 03-21-2014, 06:32 PM   #11
FlushYaris
Drives: 07 yaris 3dr
No you wont need camber. I run 17x8.25 +25 and with the 2" drop I had about 3-4 fingers of wheel gap. I have 195/40s though..
FlushYaris is offline   Reply With Quote
Old 03-21-2014, 08:48 PM   #12
Bluevitz-rs
It would also depend on what tire brand you use as well. Some tires have a lip to protect the rim which ads width to the tire.
Old 03-24-2014, 01:18 AM   #13
kropekoi
Drives: vios 1.3J
this was the drop before
this is what it looks like before
http://i149.photobucket.com/albums/s...ps2a52886a.jpg
http://i149.photobucket.com/albums/s...ps0b34a5b1.jpg
Old 03-24-2014, 01:18 AM   #14
kropekoi
Drives: vios 1.3J
Old 03-24-2014, 01:20 AM   #15
kropekoi
Drives: vios 1.3J
here's how low she is right now
drop, lowering springs, sedan, vios, yaris
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
adjustable camber bolts? b20vteg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-22-2012 10:08 AM
AG Lowering springs (2" drop) wildmongoose26 Items for Sale by private party 27 06-01-2010 12:20 PM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
New Product: Penguin Garage Rear Camber Shims! Penguin Garage Penguin Garage 11 10-22-2009 10:20 PM
