Old 02-23-2016, 11:06 PM   #1
shepd
Drives: 2007 Yaris 5 door RS
Catalytic converter pipe
The pipe connecting the catalytic converter to the muffler rotted off just about where the flange is at the muffler.
I see that Bosal has a "750-253" exhaust pipe, which is cryptically listed as "Repair pipe for 096-2609" 096-2609 on Bosal's pics is the catalytic converter.
Is this the pipe I need to fix my issue? I'm basically looking for a pipe that I could weld to the back of the converter that would end up connecting to the muffler. Or should I be looking for or ordering something else?
I'd try tin cans, but sadly, this stupid pipe has a bunch of bends in it. :(
Old 02-24-2016, 09:57 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
if you have a welder, just go to canadian tire and get a pipe that will slip over the rotted part. Grind the old pipe off the flange and weld it to the slip on and then you can clamp it on in place. I had to do this for my mother's '03 Matrix XRS.
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
Cylinder 1 misfire and catalytic converter issue Lu Xun DIY / Maintenance / Service 3 08-24-2013 06:37 AM
I am looking for the : Catalytic converter /Front and Middle Exhaust section Roth5150 UK 0 07-27-2010 06:28 PM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
catalytic converter question SamDaYarisMan Performance Modifications 14 09-08-2006 10:18 AM
