Old 09-04-2016, 05:44 AM   #1
rabbito
rabbito's Avatar
ATF flush after 45,000KM
i finally flushed my ATF after 45,000KM..some people say you dont need to flush them or change them at 100,000km etc...
i rather flush them out and put fresh fluid since i down shift often or shift through gears on my automatic transmission..
after we took out the fluid with them sucking machine thing, it was pretty burnt and dark af...
gear shifts much smoother and feels much better after the fresh atf...
rather safe than sorry..enjoy!! 😆😆😆😆
Cosmetic: Toyota red emblem
Old 09-04-2016, 12:30 PM   #2
LTHatch
Drives: 2013 Yaris Hatchback L
Do you have a transmission cooler installed? Given you manually shift your auto, better safe than sorry.
LTHatch is offline   Reply With Quote
Old 09-04-2016, 01:57 PM   #3
rabbito
rabbito's Avatar
transmission cooler? 😣....dude..auto = its a torque converter....😅
no, i dont have them installed..😂
Old 11-02-2016, 11:54 PM   #4
jefferelli
Drives: 08 Yaris HB
I think your automatic transmission should already have a stock cooler by the radiator. (at least I assume the AT Yaris has one). I never really looked at the yaris for a cooler. On my AT 4runner it is built into the radiator ( I had to swap it out a couple months ago). But this was a good reminder that I should probably go ahead and swap my fluid in the Yaris. I am a little over 100,000 so def due. But now I will look for the cooler while I am under it out of curiosity.
What kind of transmission fluid did you use? I was just going to go with Toyota atf ws but looks like you used something different in the pic?
jefferelli is offline   Reply With Quote
Old 11-03-2016, 12:00 AM   #5
rabbito
rabbito's Avatar
its also toyota ws fluid..only the packaging looks different...
i mean its only $50 here with the labor...not even a labor, machine with a sucker that just sticks in..i will just change mine every 40k...😅
Sent from my SM-J710F using Tapatalk
Complete flush for ATF change? Lance16 DIY / Maintenance / Service 29 07-05-2017 09:26 PM
Transmission Flush / Coolant Flush at 60k? ttpmurphy DIY / Maintenance / Service 7 08-29-2015 09:39 PM
Replaced my ATF markitect DIY / Maintenance / Service 6 01-02-2014 10:10 PM
ATF Drain and Fill DMZ DIY / Maintenance / Service 7 05-30-2013 11:01 PM
Do I need a transmission flush at 57K miles if 07 Yaris should last until 100k? lejulie DIY / Maintenance / Service 14 10-23-2011 07:43 PM
