Old 07-29-2006, 12:56 AM   #1
badhabitz
badhabitz's Avatar
Drives: yaris
Send a message via AIM to badhabitz
c one motorsport clutch line(pics)
alright i just finished the install today and i wanted to say thanks to www.kamispeed.com if u guys need anything for your yaris call them and ask for billy they have some stuff u guys might be interested. this install took me about 40 min including the test drive and making sure there was no leaks.
this is my first performance part other than jdm emblems for the exterior.
alright lets start so this is what the clutch line looks like from c one
the first thing i did was remove the old part u can drain it or suck out the old fluid but i just left it in there to drip. i took out the old one using a 10mm and a 13mm and pulled out the metal brakets clips holding the lines in place
next i installed the new line and clips that c one provides making sure that everything was fitted right and nice and tight if not they can leak and ur peddle will just hit the floor.
next thing i did was fill it up with more fluid and me and my friend bled the clutch by pressing on the clutch peddle about 7-10 times then holding it and bleeding it from the clutch cylinder located in front of the engine. everyone has there own way of bleeding it. anyways after the bleed i took it for a test drive and first thing i noticed when in reverse it grabs better and driving it i felt that shifting was smoother and not as jerky as it was in reverse though youll notice a big difference of not havin to rev or keep the rpms up all the time. in conclusion i was happy with this piece and recommend it a little piece like this made a big difference hope u enjoyed it my next upgrades are the performance bars first, suspension, and wheels.
badhabitz is offline   Reply With Quote
Old 07-29-2006, 01:08 AM   #2
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Drives: 2007 Yaris Liftback and S13's
A very cost-effective performance upgrade!!!
I might look into one of these in the near future. My liftback is still tough to get into reverse, even after releasing and re-engaging clutch and/or 'clicking' into other gears, first. I'm assuming this would fix the spongy-feel from the clutch..
Thanks for all the help over the years, YarisWorld!!!
TRD_Yaris is offline   Reply With Quote
Old 07-30-2006, 06:15 PM   #3
El Jefe
Drives: 07 yaris s sedan
how much is that line?
El Jefe is offline   Reply With Quote
Old 07-30-2006, 06:29 PM   #4
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Makes perfect sence.. just as you would upgrade the rubber brake lines to stainless lines for a firmer pedal feel (plus better braking!), the same would apply to the clutch line. Right on!
Old 07-30-2006, 08:03 PM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Yeah definately what is the price??
Old 07-31-2006, 12:56 AM   #6
badhabitz
badhabitz's Avatar
Drives: yaris
i paid about 90 for it shipped i know thats kinda pricey but for the brake lines they want like 3 bills but id just source that from somewhere else
Old 07-31-2006, 10:08 AM   #7
FlintS
FlintS's Avatar
Drives: 2007 Yaris S Sedan
If the brake line prices com down I would buy them. I csnt stand the brake pedal...
FlintS is offline   Reply With Quote
holy sexy clutch birdy General Yaris / Vitz Discussion 8 05-05-2006 08:34 AM
