Old 08-20-2013, 11:59 AM   #1
yaris9876
Drives: yaris hatch 07 640K original m
AC pulley
wondering if anyone has pulled the pulley off the AC compressor yet and how you got it off
and fixed any bearing issues....
yaris9876 is offline   Reply With Quote
Old 08-21-2013, 11:04 AM   #2
Taking the pulley off requires being able to hold the pulley still while turning the 7mm shaft. I made a simple tool out of a piece of flat stock and two 6mm bolts. I tapped the holes in the flat stock to allow me to adjust the depth of the bolts. To unscrew the pulley from the shaft you have to put the ratchet with the 7mm socket in the tighten, rather than loosen direction.
Once you remove the metal, outer pulley, there is a snap ring that holds the inner pulley in place. My snap ring tools was not large enough for it, so I just worked my way around it with a needle nose pliers to release it.
There is a bearing within the inner pulley that is hopefully the one that you need to replace. If the bearings within the compressor are bad, you will need to remove the bolts beneath the pulley to gain access to them:
Old 08-25-2013, 09:47 PM   #3
yaris9876
thanks
The MI LW Pulley "Not a Big 'Car Guy'" Review jpmck03 Performance Modifications 36 05-02-2013 01:38 AM
FS: NST 20% Overdrive Alternator Pulley MGargano Items for Sale by private party 12 06-05-2011 11:06 AM
FS: 2009 Alternator & Overdrive Alt. Pulley MGargano Items for Sale by private party 9 10-28-2010 07:42 AM
NST (NonStopTuning) Ebay Feedback & Rating NonStopTuning NonStopTuning 0 07-19-2009 10:11 PM
NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) NonStopTuning NonStopTuning 266 09-29-2007 02:51 AM
