Old 10-16-2014, 02:06 AM   #1
jactis
Drives: Toyota Yaris sedan 2009
A/T Jerks @ 4th Gear
Please help, I have 2009 Yaris Sedan, I have noticed that my car jerks when the gear shifts specially in 4th gear. I just had transmission fluid/filter change but jerking is still there. Thanks
jactis is offline   Reply With Quote
Old 10-16-2014, 05:22 AM   #2
Astroman
Modded Moderator
Astroman's Avatar
I have the hatch and mine does the same thing under heavy acceleration about 30 miles ago. Had a transmission shop do it but they didn't do a complete flush as they gave me extra fluid back. I posted a thread about it but to tired to find it. Never resolved it just now I let off the pedal before 4th when going up hill and mashing it. Putting it in 3rd helps on hills.
Old 12-02-2014, 09:37 AM   #3
vrizrak
Drives: 2007 Yaris Sedan
Had exactly same issue. Flushed all fluid i changed filter. Filled back in as on instruction 2.6qt took her for test ride notice jerking between 3rd and 4th gear. Came home and check level. Was very low. So I added another qt checked again was still low. Added what I had left 0.4 so total was 4qt. Took for test ride jerking was gone. However level was still low. Then I measured drained fluid was over 1gl!!!! I had 1gl empty can from milk so it overflows. Get Toyota dealership this morning and bought another 2qt. So I ended up putting 5.4qt. Technician from Toyota said actually in some cases torque converter might be in position when all "holes" lined up and it actually flushes!!
vrizrak is offline   Reply With Quote
Old 12-02-2014, 10:32 AM   #4
bronsin
bronsin's Avatar
Wow another excellent reason NOT to change the auto transmission oil!
Old 12-02-2014, 11:52 AM   #5
vrizrak
I had to flush during drive shaft replacement. :)
2nd, 4th & Reverse Gear Not Engaging mesci DIY / Maintenance / Service 3 03-17-2023 07:03 AM
Experimenting with bypassing the AT 4th gear prohibition when cold CTScott Performance Modifications 28 03-22-2015 08:16 AM
hesitation into 4th gear AT samus11 DIY / Maintenance / Service 5 12-18-2012 08:22 PM
Grinding in 4th gear? Black_griffin6 DIY / Maintenance / Service 8 05-30-2012 03:54 PM
No 4th gear in A/T? caineroad General Yaris / Vitz Discussion 13 09-11-2009 06:47 PM
