05-19-2016, 06:34 PM | #1 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Oil analysis results
Here is my 2zr's first oil analysis results. Aside from some additives and minor contamination(probably from the time this engine sat in the junk yard) it's a clean bill of health!
05-19-2016, 08:55 PM | #2 |
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
Very nice!
05-19-2016, 10:02 PM | #3 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
thanks for the post!
No one ever wants to give a Yaris the point by... |
05-20-2016, 01:45 AM | #4 |
Data doesn't lie
These tests are the best way to monitor your car, $30 test and it gives you so much piece of mind
05-20-2016, 09:01 AM | #5 |
Drives: 2009 Base Hatch 2 Dr Auto Join Date: Dec 2008
Five quarts of oil?
What else have they got wrong?
05-20-2016, 09:45 AM | #6 |
Honestly, the true dry to fill capacity might be closer to 5 qts, and I'm sure the 2zr could hold 5 without issue, so it really isn't that wrong. It holds 4.5 according to a drain and drill as per Toyota.
05-20-2016, 10:44 AM | #7 |
The 5 qts in the sump refers to the Yaris in the oil analysis.
05-20-2016, 11:20 AM | #8 |
Yes, but his Yaris has the 2zrfe in it. Maybe I'm not fully understanding this analysis. I was under the assumption, they pulled the oil from his vehicle and checked it, so he should of had at least 4.5 qts in it.
Project so far: 2zrfe swap, Megan racing coilovers, TRD rear sway bar, whiteline bushings, RPM long tube header, midpipe, and DC sports xD exhaust, brake upgrade in front, MI stainless braided lines all around, matte paintjob, Takada cold air intake, various gauges, rear seat and belts removed. Future: Turbo. |
05-20-2016, 11:29 AM | #9 |
Wow!
05-20-2016, 01:53 PM | #10 |
Data doesn't lie
These oil analysis check only 5-6oz of your oil, they need to know your sump amount to calculate your percentages. The 2zrfe is 5qts dry.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
