Old 07-29-2013, 03:14 PM   #1
33OH
Drives: '08 Yaris
Yaris is shaking :(
Hi all,
I have an '08 Yaris, 130k miles, manual trans, with a vibration - even at idle.
No CEL, and it doesn't appear to be missing.
I thought motor mounts, so I went ahead and replaced every single one, including the motor to tranny dogbone mount.
Still shaking, even worse now that I've replaced motor mounts (but probably because these are tight now with no tolerance for vibration.)
Any ideas on what to check next?
Old 07-29-2013, 05:36 PM   #2
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Possibly one of the plugs isn't firing properly due to a coil or wiring issue. This would likely show up on a proper Toyota dealership diagnostic session - maybe expensive.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 07-30-2013, 08:56 AM   #3
33OH
Drives: '08 Yaris
I do not believe it a misfire, but I did look into it at first. Also just swapped in new plugs just in case.
Thanks for the response!
Old 07-30-2013, 10:32 AM   #4
racerb
I thought you were selling this car? If it has issues, how much cheaper could I get from you now??
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 07-30-2013, 03:41 PM   #5
33OH
Drives: '08 Yaris
I was a few months ago (before it had issues) when I had my Subaru. Sold that and kept the Yaris.
Old 07-30-2013, 06:06 PM   #6
racerb
Good man, the Yaris has most likely got a simple issue, maybe even a coil-pack breaking down. At 130K, things like that can start to happen, it's pretty common!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 07-30-2013, 06:25 PM   #7
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Check the o2 and MAF sensor.
Old 07-30-2013, 09:03 PM   #8
dragoonmc
Drives: 07 hatchback
Did you recently disconnect the battery?
I did that last night and noticed it shaking bad at idle now and in didn't before but I kind of remember it doing this the last time I disconnected the battery and expect it to get better soon
dragoonmc is offline   Reply With Quote
Old 07-30-2013, 09:28 PM   #9
If it doesn't get better quickly on its own, then clean the throttle body. There is a TSB about rough idle after disconnect where the solution is to clean the carbon deposits from the throttle body.
Old 07-30-2013, 10:20 PM   #10
racerb
CTScott may be right on the money on this one, my old Rav4 used to do that until I cleaned the throttle body and MAF sensor, but be very careful with the MAF it's pretty delicate!! Worst part on the Rav, was it would actually cause the throttle butterfly to stick making taking off from a stop worse than the FBW hesitation!!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 07-31-2013, 08:42 AM   #11
33OH
Drives: '08 Yaris
Thanks Scott, I'll check the throttle body out. I remember it had some salt deposits on it anyway, so it's a good place to start. MAF was pretty damn clean, just had it out, so I'll check the TB first.
Old 07-31-2013, 07:53 PM   #12
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I'm thinking I may be in the same boat: rough idle, stalling when coasting to a stop, frequent P0171, RPM hunting, etc. My thought is that the PCV is dumping an awful lot of oil back into the Blitz intake tube--it was wet the last time I pulled off the hoses. Perhaps time for an oil catch can...
Old 08-01-2013, 08:48 AM   #13
33OH
Drives: '08 Yaris
I did have the P0171 in my code history, but it's not throwing the code now. May be completely unrelated.
I'm not having any oil inside my intake tube though.
Old 08-01-2013, 05:05 PM   #14
justjesus
justjesus's Avatar
Drives: 2008 Liftback
check for a vacuum leak as well.
Old 08-06-2013, 12:46 AM   #15
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Engine mount? Mine is kinda vibrating too.
Old 08-06-2013, 03:10 AM   #16
jRoss
Drives: 2010 5spd sedan
My engine shakes too, can't really figure out why. The only thing I have installed under the hood is an MI pulley which I have since reinstalled. I fear the worst, maybe I tightened the belt too tight and it bent the crankshaft or something. Idk what the heck to do :/ but I've tried everything I know to fix it and it continues to shake but runs fine for now...
jRoss is offline   Reply With Quote
Old 08-15-2013, 03:59 PM   #17
33OH
Drives: '08 Yaris
Did this, no avail. Any other thoughts?
Old 08-15-2013, 04:12 PM   #18
Hmm if that did not help, it could be any of the above (MAF, coil pack going, etc. or it could be a fuel issue (dirty injectors, plugged filter).
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
