Old 10-19-2018, 03:12 PM   #1
JDJanitor
Drives: 2016 yaris
2016 HB doors won't lock with lock button
When I hit the lock button all the doors lock, and immediately unlock. This just started today.
Sent from my moto x4 using Tapatalk
JDJanitor is offline   Reply With Quote
Old 10-19-2018, 04:03 PM   #2
Using the key fob or interior lock button?
Old 10-19-2018, 04:20 PM   #3
JDJanitor
Drives: 2016 yaris
Interior lock button, I don't have any key fobs.
Old 10-19-2018, 05:21 PM   #4
JDJanitor
Drives: 2016 yaris
If I lock it with key from outside, it works.
If I push the lock to the locked position manually, it unlocks electronically
Old 10-19-2018, 08:33 PM   #5
JDJanitor
Drives: 2016 yaris
If I use the ignition, and move it from run to off, and while pulling the key out hit the lock button, it works. But if I hit it a second time it unlocks.
Maybe my issue is in the key hole
Old 10-19-2018, 09:45 PM   #6
JDJanitor
Drives: 2016 yaris
Problem SOLVED
I had plugged a small power Bank in to charge, it must have somehow supplied power backwards, because when I unplugged it, and hit the lock button it worked every time.
I pulled every fuse I blew out all the switches, and ignition with compressor I must have hit the lock button over a hundred times.
Doors Won't Lock TutorMe DIY / Maintenance / Service 3 08-05-2014 03:04 PM
Shouldn't the doors lock... imike929 Third Gen Yaris General Discussion 24 04-29-2014 09:28 PM
Radio stays on, doors won't lock jtown General Yaris / Vitz Discussion 7 07-16-2012 09:53 PM
Yaris Key fob wont lock my doors! Treeny DIY / Maintenance / Service 3 03-29-2012 07:27 AM
center console lock button ryota General Yaris / Vitz Discussion 10 12-16-2009 01:34 AM
