11-14-2022, 11:58 AM | #1 |
Drives: 2007 Yaris Hatch Join Date: Sep 2019
Front strut mounts replacement: OEM or Aftermarket?
My Yairs is nearing 140k miles and it's time to replace the struts and rear shocks. I bought TRD shocks, TRD springs, bushings, strut mounting plates, bearings and most of the other required hardware from Toyota. The last thing I need to buy before I complete the job is front strut mounts. KYB strut mounts are $39 at my local auto parts store or $98 from my local Toyota dealer.
I think deciding to go down the aftermarket or OEM parts route typically just comes down to personal preference, but figured I'd ask anyways. Personally, I'm leaning towards OEM since I drive over 35k miles a year and I want maximum reliability and cornering performance. I can’t have my car out of commission long and I don’t want to touch the suspension again anytime soon, but of course paying over double is insulting. Anyways I know I’m over thinking this, but what are your thoughts? Last edited by Ecefour; 11-14-2022 at 12:11 PM. |
11-16-2022, 05:18 PM | #2 |
Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
you have done a great job with keeping the suspension nice and factory woth trd parts, might as well do it 100% not 90%, get the oem mounts
12-16-2022, 11:35 PM | #3 |
Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
12-17-2022, 01:15 PM | #4 |
Drives: 2007 5dr canadian import Join Date: Dec 2016
12-17-2022, 03:00 PM | #5 |
Yeah KYB makes just about all the japanese car companies OEM shocks and a bunch for other car companies from else where.
I will not buy Munroe we had so many come back failed leaking in warranty period that I do not trust anything they make, we always recomended KYB over munroe even tho they cost more. |
12-18-2022, 01:56 AM | #6 |
TBH kyb is the bottom of the barrel for me..its what ill grab is i cant afford better, with "trucks" being the exception..some of them gabrials work well
i tend to lean heavy on koni and bilstien |
12-24-2022, 03:40 AM | #7 |
false, the kybs are far different than the oems, kyb makes them for toyota with their standards and specs
12-26-2022, 03:57 AM | #8 | |
Back in the 90's for a lot of the random JDM models imported to NZ the only way to get replacements was with the KYB serial number stamped on the OEM kyb which I would then get in the exact same serial number stamped shock Direct from KYB to replace them. |
12-28-2022, 02:25 PM | #9 |
must be a european market thing then, US spec toyota shocks compared to kybs brand are completely different, especially when it comes to trucks like the tacoma and tundra
12-28-2022, 04:01 PM | #10 |
with trucks i expect that..as they can get away with a broader interchange as well as longer(lifted) shorter(lowered) and then the fact that 1 shock may fit multiple brands and models across a decades worth of them..where cars are mostly made to a specific model...
12-31-2022, 10:21 PM | #11 |
3 years ago I replaced the struts and shocks with the black KYBs and also bought KYB strut bearings. The bearing were absolute junk.....so much so that I just reused the OEMs. Despite having 150k miles on them they were much more solid feeling than the KYB turds
If you want to enjoy your car, stay off of the internet. |
01-02-2023, 04:21 AM | #12 |
Can't say Ive ever used KYB bushings just the shocks. I always put Nolathane bushings in cars I owned in the past.
Similar Threads | ||||
ABS Code Keeps Returning After Sensor Replacement Code 31 Front Right | Chwbcca | DIY / Maintenance / Service | 5 | 09-15-2021 08:16 AM |
MOT advisory for Macpherson Strut Mounts | JohnGYaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 09-04-2020 05:08 AM |
OEM vs Aftermarket Water Pump? | antone | DIY / Maintenance / Service | 0 | 10-23-2012 12:25 PM |
WTB OEM Vitz front badge | devinlamothe | Willing to Buy by private party | 0 | 03-31-2012 07:41 PM |
C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) | bigsky2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 01-10-2007 06:53 PM |
