11-17-2008, 04:13 PM | #1 |
Start another Oil Thread!
Paddle Shifting (for MT)
good afternoon everyone..
i am in the process of building a paddle-shift system to be used on any manual transmission that utilizes cables for shifting. the system will utilize two pneumatic cylinders with positional feedback switches, 4 three-way pneumatic valves, a PLC, a small air compressor and tank, and switches mounted either to a sandwich adaptor (for aftermarket 6bolt steering wheels) with paddles integrated or limit switches to be mounted under the shifter to sense fore-aft motion. i currently predict this kit to sell for around $1000.. anyone interested? |
11-17-2008, 04:21 PM | #2 |
SIPNDEW
well it definately sounds awesome! i am more of the normal manual shift type but for those who want paddles its your chance! :)
11-17-2008, 04:23 PM | #3 |
fyi your clutch will be fully functional (and required) and i will integrate a small air cylinder to blip the throttle on downshifts..
11-17-2008, 04:49 PM | #4 |
SIPNDEW
thats cool. but can you retain the stock shifting mechanism for street driving if you choose?
11-17-2008, 05:19 PM | #5 |
Drives: 07 Yaris Turbo Join Date: May 2007
Looking forward to pics and a review of your prototype
11-17-2008, 10:37 PM | #6 |
Drives: 07 metmet LB Join Date: Oct 2008
This would be cool as sh*t
F5 CAI, MR axleback, MR Header, NST SSK. Full Exhaust wrap, AT3 Custom SSK Konig Heliums 15x6.5 Black Tanabe Df210's |
11-17-2008, 10:44 PM | #7 |
Bathroom + Laptop = <3
http://www.m7tuning.com/parts/produc...roducts_id=123
Mini also has a system like this you might want to check out for ideas and whatnot... looks promising.. |
11-17-2008, 11:31 PM | #8 |
Beast
would they work in AT? i got confused by the website selling em for Automatic?
One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
11-18-2008, 08:41 AM | #9 | |
first, it's only for transmissions with the stick ON the trans (RWD setups) second all they show you is pretty pictures of the paddles. here's my work so far my initial design will be for MT only. here's my chicken scratches from last night.. and my truth table.. gotta integrate this into the programming now.. my brain hurts i1-i4 are cylinder position feedback inputs (so the PLC knows what gear you're in) i5 is "upshift" input from the paddles i6 is "downshift" input from the paddles Q1-Q4 are outputs for the valves that will control the cylinders |
11-18-2008, 08:45 AM | #10 | |
Drives: 2008 Toyota Yaris Liftback Join Date: Oct 2008
great work! |
11-25-2008, 07:23 AM | #11 | |
Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
Their Street Manual All Products page shows good images of the actual modules that bolt in place of the stock shifter assembly to control the existing cable-drive stuff. *ALL* their systems are designed to work with cable-driven transmissions actually.
11-25-2008, 08:34 AM | #12 | ||
either way, the intent of my setup is to do away with cables ;) |
11-25-2008, 12:04 PM | #13 | |
The MasterShift kit comes with a programming cable and software CD for a reason: It's for setting the distances the box actually has to shift the cable-linkages for the gate-selector and syncro-selector inputs, and specifying paths and routes for the shifting to follow. And any cable linkage can be replaced with a hydraulic linkage, witness modern brakes versus the old cable-powered brakes used as recently at the 80's. Hell, many vehicles with in-board brakes (brakes mounted beside the differential, bolted to the chassis instead of part of the wheel assembly, Jaguar's and Hummer-1's mostly) can have hard brake line going all the way to the brake calipers. They'd use hydraulics more places, but it's a lot more expensive to design and prone to maintenance headaches than a length of steel rope inside a plastic sheath, which is almost all a transmission-cable is since it doesn't have to deal with large forces like brakes do/did. Didn't mean to come off as knockin' on the work you're doing, it's looking awesome so far. :-)
11-25-2008, 12:36 PM | #14 | |
i'm jealous of their paddle controls :( |
11-18-2008, 08:47 AM | #15 |
well, I'm certainly interested in the technology behind it, it is an awesome project, too bad you can't integrate the clutch
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson Bye bye 1NZ... |
11-18-2008, 08:47 AM | #16 |
11-18-2008, 02:57 PM | #17 |
§†ęĄ¶‡Ћ-NCP96
11-18-2008, 08:54 AM | #18 |
well doing it as a clutch override would be ideal I guess, so you retain normal control of it. Seeing as it's a hydraulic setup (at least on our cars, not sure about the xA), it should be possible given the right engineering? Or maybe as a future upgrade
Similar Threads | ||||
Didn't buy; awkward shifting? | drmitch | New YARIS Purchase Forum | 89 | 03-03-2009 09:44 AM |
Yaris Auto Transmission shifting | g man | Canada | 9 | 08-23-2007 12:16 PM |
Shifting (A/T) | daq421 | General Yaris / Vitz Discussion | 54 | 04-03-2007 12:30 PM |
Paddle Shifter? | spkrman | Performance Modifications | 10 | 03-09-2007 05:17 PM |
Sticky When Shifting and Sticky When Reving? | jouslee | DIY / Maintenance / Service | 22 | 01-23-2007 11:07 PM |
