02-05-2009, 11:21 AM | #1 |
Drives: Polar White Yaris HB Join Date: Dec 2008
How to remove the inner plastic front fenders
Hi Guys,
I need some help with removing the inner plastic liners from the wheel wells. I am trying to block some of the annoying road noise and need access to the metal! It looks like I could just get a panel remover or other flat tool and pry the little clip things out. The front two appear different. Thank in advance |
02-05-2009, 02:29 PM | #2 |
Drives: yaris 08 sedan Join Date: Oct 2008
A $2 pair of sponge ear plugs might be a lot less hassle.
02-05-2009, 02:54 PM | #3 |
Great idea......
02-06-2009, 10:17 PM | #4 |
Drives: 08 liftback 5spd Join Date: Oct 2008
umm i use a big screw driver and replace any that i break. but im not posting to be helpful. please update! with results as im interested in doing something similar once it gets above freezing for a few days straight...
02-07-2009, 03:54 AM | #5 |
Will do
02-07-2009, 04:12 AM | #6 |
Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Go to the following thread.
http://www.yarisworld.com/forums/showthread.php?t=1768 Download the factory manual called "exterior trim". The instructions might be different depending on whether you have a liftback or sedan.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
Similar Threads | ||||
How hard is it to remove side skirts and front lip on 08 sports package? | dono37 | Cosmetic Modifications (Exterior/Interior) | 15 | 09-26-2007 05:28 PM |
How to remove front Door Panel Speakers?? | skateboarddziner | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 09-22-2007 12:04 AM |
How can I remove the yellow front signal plastic? | Push | Cosmetic Modifications (Exterior/Interior) | 12 | 06-28-2007 01:36 AM |
Remove Front Light | Rogerah | DIY / Maintenance / Service | 1 | 11-21-2006 06:19 PM |
How do i remove plastic interior? | David81 | Cosmetic Modifications (Exterior/Interior) | 1 | 06-09-2006 09:07 AM |
