Old 04-24-2009, 09:40 AM   #1
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Konig Helium + Falken RT-615s installed (Pics!)
205/50/15 Falken RT-615, 15x6.5 Konig Heliums 40mm offset, aluminum hub-centric rings from Discount Tire, Autozone "tuner" locking lugs. THE OEM LUGS DO NOT FIT IN THESE WHEELS. I annoyingly discovered that when I first tried to put them on
More pics:
http://picasaweb.google.com/schleppy/2009Yaris#
I love the look of the combo, but now I realize how badly the car needs to be lowered a little bit. Oh well, in due time.
The tires are definitely a lot stickier, but still have that "break in squirm". On the highway with the steering wheel centered they seem to float a little. I'm sure that will go away in the first 100 miles or so. Also, I know the tires are asymmetrical, but they also look like they're directional. On each side of the car the outermost treads are "pointing" in different directions, even though both sides have the "outside" label facing out. The tires don't have any directional arrows on them. Any ideas?
Also, can anyone recommend a good F/R tire pressure? Falken told me I should run 31 psi all around, 33 psi for highway driving. Those numbers seem really low to me. I've heard autoxers running 38 front, 40ish rear.
If anyone has any questions fire away!
Old 04-24-2009, 09:43 AM   #2
33OH
Drives: '08 Yaris
FYI - It's not uncommon for aftermarket wheels to require longer, narrower, "tuner lugs".
Looks good though!
Old 04-24-2009, 10:24 AM   #3
schleppy
I love momentum.
schleppy's Avatar
Looks good though!
Thanks!
And yeah, I should have known better. On wheels this tiny the big ass acorn lugs rarely fit. I was so close to ordering lugs last week but I thought I could get away with it. Thankfully Autozone had what I needed.
Old 04-24-2009, 09:45 AM   #4
ChinoCharles
Drives: LB
Old 04-24-2009, 10:09 AM   #5
Mavix
Drives: '91 Hilux, '91 Cervo Mode
I ran these same tires at a race school this last weekend. Those pressures are pretty low but it's also what I was told to run on the tires and it worked really well. Azenis have pretty stiff sidewalls which is why I was told the lower pressures are safe in this tire for track use. I run them a bit higher when im just driving on the street.
Mavix is offline   Reply With Quote
Old 04-24-2009, 10:26 AM   #6
ChinoCharles
Drives: LB
VERY nice.
Old 04-24-2009, 10:38 AM   #7
yeah those "tuner" lugs have tapered ends, and most aftermarket wheels have a matching taper at the bottom of the lug hole, so the lugs will help to align the wheel perfectly...
Old 04-24-2009, 04:03 PM   #8
Mobius1
Installer
Mobius1's Avatar
Drives: 2008 Yaris HB
looks good. Coincidentally i just ordered those same rims today from JLB for my meteorite. One of the best bang for the buck rims I have found
Mobius1 is offline   Reply With Quote
Old 04-24-2009, 04:07 PM   #9
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
i found this and am now unsure about purchase.
http://www.yarisworld.com/forums/arc...hp/t-2328.html
Old 04-24-2009, 04:22 PM   #10
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
Eh, when I was looking to pick up some Heliums, I looked up breakage because I was worried as well, but it seems there are very few posts online about failures, and several members here have ran them without issue.
Even so, I do enjoy having the real wheels instead.
Old 04-24-2009, 05:32 PM   #11
justjesus
justjesus's Avatar
Drives: 2008 Liftback
Air pressure is also different when the tires are cold or warm (or hot). Air pressure increases with heat.
I used to want this exact combo. It's cool. Nice color choice for your red yaris
Old 04-24-2009, 09:18 PM   #12
schleppy
I love momentum.
schleppy's Avatar
I too read about the Helium failures, but I'm not going to worry about it. They happened a while ago, and there are TONS of Miata guys that have been running wheel happily for a long time.
Thanks for the positive words all!
Old 04-24-2009, 10:39 PM   #13
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
OK if I can run Helium's on the roads we have up here (as in the roads are literally disintegrating into dust and holes everywhere) I'm sure they will be good unless you run a really thin tire.
Great looking rims btw, I have the same ones!
devinlamothe is offline   Reply With Quote
Old 04-26-2009, 05:14 AM   #14
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
err that's rather bizarre... looking at the tread pattern it seems like you would have grip differences in the rain between both sides...
Old 04-26-2009, 05:17 AM   #15
CtrlAltDefeat
I ♥ Yaris
oh yeah and a question: What are hub-centric rings?
Old 04-26-2009, 09:21 AM   #16
schleppy
I love momentum.
schleppy's Avatar
That's what I thought, but fellow RT-615 owners said that's the way it is. I'll call Falken on Monday and ask.
Old 04-26-2009, 09:20 AM   #17
schleppy
I love momentum.
schleppy's Avatar
Hub-centric rings are rings you put in the back side of an aftermarket wheel that make it sit snugly on your cars hubs. This helps prevent vibration from an ill-seated wheel. They are CHEAP and worth it (don't buy plastic ones either, get aluminum ones).
Old 04-26-2009, 10:07 AM   #18
CtrlAltDefeat
I ♥ Yaris
ahh interesting... one more question, I'm interested in this same setup, possibly. How much did the who set cost?
falken, helium, konig, rt-615, wheels
BEWARE of Konig Helium (Pic & Video) !! SimmZ Wheels, Tires and Suspension Forum sponsored by The Tire Rack 71 10-05-2010 05:32 PM
Flint Mica S Sedan, Bronze Konig Helium, NF210 Springs, und Tint flint_mica_manual Photo-Video-Media Gallery 6 05-09-2007 02:25 AM
Konig Helium bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 11-26-2006 01:48 PM
KONIG HELIUM Ultra LIght Weight wheels C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 31 08-03-2006 06:00 AM
