Old 10-13-2010, 02:55 AM   #1
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Changing interior lights
Hi everyone how do I get all my interior colored specifically like red or blue etc any DIY guides or links to bulbs I have a 2010 yaris and I hate the yellow lighting dont know what it is but yellow hurts my eyes bad even when its sunny out I wear blue colored shades and all the bulbs in my house are specifically white just for me lol
appreciate this alot and how much it would cost avg to have all my interior lit up
Old 10-13-2010, 02:59 AM   #2
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
Hey Kevin, you can check the posts here http://www.yarisworld.com/forums/showthread.php?t=30871
and check at www.superbrightleds.com
They've got several colors.
chrisj is offline   Reply With Quote
Old 10-13-2010, 03:04 AM   #3
Map lights are 194 wedge types. The dome light is a 3175 festoon (I believe). Check out my sedan:
You can get the 194's here: http://www.v-leds.com/194-168-158-LED/c122170-1-2/
and the 3175 here: http://www.v-leds.com/3175-6418-3022...orLanding/true
Old 10-13-2010, 03:06 AM   #4
Trunk in the sedan is also a 194 wedge (I have 3 6" strips in the back converging to the 194 holder). The license plate lights are also 194 (IIRC).
Old 10-13-2010, 10:34 PM   #5
pspeezy
Drives: 09 Yaris Sedan
so let me get this straight, 194 wedge type for map, trunk, and license plate lights?
(for my 09 yaris sedan, thats 2 map lights, 2 license plate lights, 1 trunk light)
so when buying bulbs for these 5 lights, i should buy 5 of the same kind, correct?
then just a festoon bulb for the dome light?
also what does 'IIRC' mean?
pspeezy is offline   Reply With Quote
Old 10-14-2010, 04:34 AM   #6
Yes, that is correct. However, I suggest getting a strip for the trunk and use a 194 holder. A single 194 LED won't illuminate the trunk very well.
Yup, that festoon I posted for the dome light.
Old 10-14-2010, 01:17 PM   #7
pspeezy
thanks man! im ordering my lights tomorrow
Old 10-14-2010, 04:45 PM   #8
No problem, don't forget to post pics when you get them installed.
Old 10-13-2010, 03:23 AM   #9
.Kevin.
I ain't even mad
.Kevin.'s Avatar
How did you get those blue lights, got any links to the specific bulbs, I suck ass at anything involving wiring or codes feels bad man.
Wanted to change the interior roof ones, feet if possible, and trunk one would be sweet.
is it like any other light bulb unscrew and screw in or what
Old 10-13-2010, 03:32 AM   #10
I actually hate the fact that the blue ones are blue. I ordered "white" LED strips on eBay to use for footwell and engine bay lighting, but each time, they came out blue. It's a little more involved to install footwell lighting as you will have to splice into two wires behind the driverside glove/coin compartment. But CTScott told me which wires to splice into (there's a picture floating somewhere here as well), and it's just a matter of hiding the wires (you'll also have to solder wires onto the LED strip because it won't be long enough if you don't). It's not hard, but like I said, more involved.
The dome, map, trunk, and license plate lights just pull out (no unscrewing) once you get their respectable covers off. If you're planning on using strips for the trunk, you'll need to purchase a 194 holder (I believe the link I gave you sells holders [look at the left side of either page]). Just remember, put in the LED, test to see if they turn on (if they don't take out the LED and flip it, then put it back in).
You can purchase the strips from the site I gave you, or just search on eBay for either blue or white (will most likely come out blue) LED strips in eBay motors.
Old 10-13-2010, 04:39 AM   #11
.Kevin.
I ain't even mad
.Kevin.'s Avatar
I guess I will swap the pull out ones since the others involve more complicated stuff, I would pay to get it done but no one here lives nearby.
Is it possible to get colored dome ones and take off the dome caps and just replace em or what
Old 10-13-2010, 08:13 AM   #12
ross sez
Drives: 08 Yaris 5spd Sedan
If you want different colors, just buy the different colored LEDs. You dont need to change the dome/map, etc.. lights' cover for the color effect.
ross sez is offline   Reply With Quote
Old 10-13-2010, 06:56 AM   #13
custom Lftback
custom Lftback's Avatar
My light conversion cost me about $50. Dome light, map lights, parking lights, liscense plate light, A/C lights, and my the gear light next to my shifter
C-Lift
Old 10-13-2010, 08:57 AM   #14
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Tail lights:
LINK
License Plate and Trunk:
LINK
Map Lights:
LINK
Dome Lights
2 of this in natural white...
LINK
Rear turn signals:
LINK
Head Lights and Fog Lights
HID 5000k and 3000K (fog lights)
I hope it helps!
CLA 250, 4MATIC
Old 10-13-2010, 06:24 PM   #15
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Thanks for all the links, atm I wanna change the two in the front that you push to turn on and the one in the middle of the roof inside, red would be nice got any link to that and how do I go abouts taking those covers off without damaging anything.
Thanks for dedicating the time, I actually like all the stock lights on the exterior
Old 10-14-2010, 04:46 AM   #16
Take a thin flat head screw driver. Look at the map/dome light covers, You'll see some "lines" at the edges (of the long side I believe). Insert the screw driver there, and gently pry off. If you'd like, remind me after 10 am (Pacific time) later today, and I'll take pics of the process.
Old 10-13-2010, 06:57 PM   #17
chrisj
chrisj's Avatar
^ Map light covers are easier taken off if you push up on one at a time like you're turning it on. Then put a screwdriver in and pop it down. I couldn't find an easy way into that light cover until I accidentally pushed up on it, then popped it out in 1 second. Goes back in really easy too.
On the dome there is a place on the edge to put a screwdriver in the pop it off.
I changed out my whole interior in like 2 minutes. Simple. Best thing is, it's so easy to change that if you get tired of one color, go with something else. Go with green and red for Christmas! ;)
Old 10-13-2010, 07:20 PM   #18
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Alright freaking sweet man now to find the bulbs for it - any help apprecciated lookin for red mostly
Yaris Throttle over-revs changing up Badger DIY / Maintenance / Service 26 08-22-2014 08:19 PM
changing alloys color zachryboles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-19-2010 10:38 AM
Just changing the blubs? Taiyaki In Car Entertainment + Electronics (audio / video / alarm) 5 04-21-2009 04:16 AM
Changing the oil lita_g DIY / Maintenance / Service 18 10-28-2008 01:59 PM
About Engine Oil Changing Manual hans_fh DIY / Maintenance / Service 4 03-03-2007 10:20 AM
