Old 05-09-2011, 10:44 PM   #1
FS: OEM Toyota Vios Turbo Kit
This is a genuine Toyota OEM turbo kit for the Vios (2003-2007) with the 1NZ-FE engine. A limited number of these kits were sold in Thailand.
This kit should be a direct bolt-on for first generation Yaris Sedans, Yaris Liftbacks, and Echos. The kt includes an incredible number of parts including the turbo, manifold, intercooler, air, water and oil piping, oil filter adapter, fuel injectors, spark plugs, thermostat, gaskets, hardware, and emissions labels.
I purchased this kit from MicroImage last year, intending to install it in my 09 Yaris Liftback. I test fit the turbo, manifold, Intercooler and air piping on Crashy to determine the compatibility of the kit with 2nd generation (2006-2011) Yaris.
Their are some differences between the 1st and 2nd generation Yaris that will require some modifications to this kit to allow it to work on a 2nd generation Yaris:
1. Intake location - The 1st gen Yaris had the Air intake and battery positions swapped versus the 2nd gen. The kit includes piping to mate to the 1st gen airbox, but use of an aftermarket air intake easily resolves the issue for 2nd gen.
2. Manifold to exhaust connection - Although the stock 2nd gen manifold and the kit's manifold are almost identical in length, position of the connection to the exhaust, and diameter of the connection, the flange is a bit different. The 1st gen flange's bolt holes are closer together than the 2nd gen. An adapter plate could be fabricated to resolve this.
3. No O2 sensor bung on the manifold - The 1st gen only had one O2 sensor, so this kit lacks the bung for the O2 sensor on the manifold. For using this kit with a 2nd gen, the manifold could potentially be drilled and tapped for the 2nd sensor, or a bung could be added to the exhaust pipe, close to the flange. Also, if standalone management is used, the 2nd sensor could potentially be eliminated.
I did quite a bit of research after purchasing the kit, attempting to find documentation on it, but the only thing I was able to locate was the diagram below.
I am selling it because I just don't have the time to work through the install for my 09, and I recently purchased a Blitz Supercharger for a quick install.
I paid $2600 for the kit and am asking the same amount for it. Shipping will be between $50 and $100 in the US. I am willing to ship it outside of the US and can find out the shipping cost to do so upon request.
Pictures:
All of the parts included with the kit:
A picture of one of the kits mounted on a 1st gen Yaris:
The diagram:
The Turbo and manifold:
Test fit of the intercooler and air piping on Crashy:
Test fit of the manifold with the turbo on Crashy:
Comparison of the kit's manifold to Crashy's 08 manifold:
Comparison of the exhaust flange of the kit versus Crashy's 08:
CTScott is offline
Old 05-09-2011, 11:02 PM   #2
EckoDG
Banned NOT!
Drives: Car
If i had the money, ill take it.. Any monthly payment in this? Haha if i can has it will be installed in 3 days for sure working good!
EckoDG is offline
Old 05-10-2011, 02:12 AM   #3
computerlove87
The Fit is NO!
computerlove87's Avatar
Drives: '09 3DR "S"|'87 Caddy Brougham
Send a message via MSN to computerlove87
How does the management work on this kit? would you either need to find a factory turbo ecu or use standalone? or is it plug and play?
My OTHER car
Please ignore the Ferrari
computerlove87 is offline
Old 05-10-2011, 06:15 AM   #4
It is low boost, similar to the Blitz supercharger, so the stock ECU should be able to manage it, but as I mention in the text, for a 2nd gen car, a standalone would be one solution for the lack of a 2nd O2 sensor with the kit (since the 1st gen only had one).
CTScott is offline
Old 05-11-2011, 02:05 AM   #5
yaris 2sz
www.yarisclub.gr
yaris 2sz's Avatar
Drives: yaris 1.3 2sz - 1.33 1nr
It is low boost, similar to the Blitz supercharger, so the stock ECU should be able to manage it, ).
the stock can not.
ithink that this kit has different injectors too
yaris 2sz is offline
Old 05-10-2011, 03:30 AM   #6
.Kevin.
I ain't even mad
.Kevin.'s Avatar
^ This
and it fits the sedan then right? if still up in a week or so I will pull this puppy.
.Kevin. is offline
Old 05-10-2011, 04:20 AM   #7
Originally Posted by .Kevin. View Post
^ This
It came off of the first gen Soluna Vios. With the modifications and management that Scott mentioned, it's possible to make it work on the second gen Vios.
Kaotic Lazagna is offline
Old 05-10-2011, 04:23 PM   #8
camelll
Drives: 07 sedan
Bump and good luck with sale!
camelll is offline
Old 05-10-2011, 04:34 PM   #9
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
any idea on the HP increase or PSI for this thing?
Shinare is offline
Old 05-10-2011, 04:42 PM   #10
The Toyota Specs for the kit are:
143 HP @ 6400 RPM
196 NM Torque @ 4400 RPM
"Light" Boost (I believe that I read somewhere that it is 0.7 Bar)
CTScott is offline
Old 05-11-2011, 02:17 AM   #11
computerlove87
The Fit is NO!
143 HP @ 6400 RPM
The blitz comes with some kind of piggyback doesn't it?
My OTHER car
Old 05-11-2011, 07:53 AM   #12
The blitz comes with a fuel controller that increases the duty cycle of the injectors to accommodate for the increase in air. This kit includes higher flow injectors, which theoretically achieves the same effect.
I can't guarantee that it will work without management, but in doing research on the kit I had run into threads on a Singapore based forum that discussed installing the kit and it was done without management. The TRD turbo kit, which was basically the same kit offered in Japan, included a new tuned ECM for the first gen Vitz, but the Thai kit did not.
CTScott is offline
Old 05-11-2011, 05:16 AM   #13
henry33
Drives: yaris1.33
this is amazing if only this fit to my engine :)
henry33 is offline
Old 05-20-2011, 10:27 PM   #14
bump...
CTScott is offline
Old 07-08-2011, 09:40 AM   #15
Bump and price drop. I need to free up some cash for other projects, so I am willing to do $2,000 shipped within the US and $2,200 shipped to anywhere outside of the US.
CTScott is offline
Old 07-08-2011, 11:01 AM   #16
matthewai
matthewai's Avatar
Drives: it is kinda stock
i deleted my post but not in time cuz i figured oh yeah you didnt have the shipping included my buss but good luck i would want it but i dont think i could do it in the near future
matthewai is offline
Old 07-08-2011, 11:45 AM   #17
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
So it's pretty much everything except management right?
Bluevitz-rs is offline
Old 07-08-2011, 11:51 AM   #18
Correct
CTScott is offline
kit, turbo
Toyota recalling 1.53 million cars globally fnkngrv Off-topic / Other Cars / Everything else Discussions 2 10-21-2010 02:26 PM
TW or FS: OEM Toyota T-Sport wheels 17x7 w/ tires Cosworth Items for Sale by private party 17 05-04-2010 02:08 AM
))) bolt on greddy turbo kit ((( aucorium Performance Modifications 5 02-14-2010 03:32 PM
Bolt on turbo kit for our yaris! aucorium Forced Induction Forum 57 02-02-2010 07:50 PM
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
