08-29-2014, 09:10 PM | #1 |
Lightweight Flywheel
ok so im considering to get the lightweight flywheel from MI
http://shop.microimageonline.com/Lig...-2-617-5ST.htm However, just need a few reviews on it like if it makes a huge difference/how it feels and if i can use it with the stock clutch |
08-29-2014, 09:42 PM | #2 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
yes, huge difference, granted mine went in with a stage 4 springless 6 puck clutch so that added to it, but the increased rev rate and amplification of torque will be noticeable.
further information on what I did. http://www.yarisworld.com/forums/sho...lywheel&page=2
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
08-30-2014, 06:45 PM | #3 |
Sounds like a good buy then but did u upgrade your clutch because it is required?
08-31-2014, 11:06 AM | #4 |
Only Happy When it Rains
It is not required to upgrade the clutch, however if you ever want to install a racing clutch the time is to do it when you put in a lightweight flywheel, because it is in the same area and needs to be taken out anyways.
Colin Chapman disciple |
12-26-2014, 11:38 AM | #5 |
Drives: Yaris Sedan YRS Join Date: Mar 2013
Does this lightweight flywheel from MI will only be applicable on a 1nz-fe or is it interchangeable to 2nz-fe?
Tags |
clutch, flywheel, lightweight, transmission |
Similar Threads | ||||
Lightweight Flywheel for the Yaris? | NonStopTuning | Performance Modifications | 51 | 03-21-2014 02:57 PM |
Questions for new flywheel and clutch | mrbond | Performance Modifications | 11 | 07-11-2013 07:17 AM |
Flywheel question-1nz conversion-2003 Model | Echo56 | DIY / Maintenance / Service | 0 | 05-21-2013 10:42 PM |
CCI Lightweight Flywheel Review | H3LlIoN | Performance Modifications | 32 | 05-06-2011 11:51 AM |
lightweight flywheel from fidanza | dngz | Performance Modifications | 34 | 02-03-2009 11:02 PM |
