Old 03-08-2009, 04:45 AM   #1
Yaris T-Sport
Nov 2006
Drives: Vitz S1600
Cold Air Induction|Blitz SUS POWER Air Cleaner System|2.4L 2AZ-FE Throttle Body|Blitz Compressor System|Full Light weight pulley kit|GReddy Ti-C exhaust System|Blitz Throttle Controller|T/B Coolant Bypass + Gasket Trimmed|Weight deduction|Exhaust Manifold|Center pipe|PCV Bypassed
Yaris T-Sport is offline   Reply With Quote
Old 03-08-2009, 04:51 AM   #2
wow excellent idea!
Old 03-08-2009, 04:58 AM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Awesome info! Thanks
Old 03-08-2009, 08:31 AM   #4
WolfWings
WolfWings's Avatar
Drives: Silver 2007 3Dr - Gryph
This bit of info let me dredge up something that might explain why earlier folks had fewer issues with the throttle-body swap.
Some Corolla's came with throttle bodies with ID #22041 on the chip housing. Others have that problematic chip-housing with ID #0D031. What'cha wanna bet the #22041 chip is special in some way? :-)
WolfWings is offline   Reply With Quote
Old 03-08-2009, 05:52 PM   #5
yarstar
Drives: 2008 Absolute Red HB
DUDE YOU ROCK!!!
Thank you for solving this issue for us. I can now finally install mine without a CEL coming on.
Does this also solve the high rpm when cold problem?
This is great. I am so stoked to get this on the car. It truly makes a difference that can be felt.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 03-08-2009, 06:20 PM   #6
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Do I need to drill through the bolts in order to crack open the TBs? Is there a better/safer way to accomplish this?
Also, what is the best way to trim the intake tube to fit the new diameter?
Old 03-08-2009, 06:35 PM   #7
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I believe they are riveted, so you will most likely have to drill them out. or be really careful prying them out
Edit, nevermind, he beat me to it.
Old 03-08-2009, 10:16 PM   #8
yarstar
Cool. I'll take the high rpm at cold idle if we can get rid of the CEL.
Thanks again T-Sport. This made my day.
Old 03-08-2009, 10:20 PM   #9
AlexNet0
AlexNet0's Avatar
mind if i make this a pdf for sticky posting if the mods want it?
Old 03-08-2009, 11:41 PM   #10
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
ok so bigger TB means more air coming in? What is the performance gain with it?
Good? i have stock intake with K&N Drop in filter, do i need to change my intake?
The difference between fiction and reality? Fiction has to make sense. --Tom Clancy
Arkhangel is offline   Reply With Quote
Old 03-09-2009, 12:23 AM   #11
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
can anyone confirm after driving over 100 miles that no cel comes on?
BTW this thread is awesome! thanks for doing this!
mikenacarato is offline   Reply With Quote
Old 03-09-2009, 01:18 AM   #12
gwasabi
Drives: 07 Blazing Blue LB
no CEL over 100 MPH
gwasabi is offline   Reply With Quote
Old 03-09-2009, 02:00 AM   #13
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Good work on figuring this out. Where did you get a 1zz tb? At a junkyard?
Old 03-09-2009, 02:28 AM   #14
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
this it?
http://cgi.ebay.com/ebaymotors/TOYOT...Q5fAccessories
Old 03-09-2009, 04:38 AM   #15
FunctionSpec
Super Newbie
FunctionSpec's Avatar
Drives: 2007 Yaris Liftback White
I've had my 1ZZ TB on for over 20K miles and never had a CEL or oscillation of any kind.
You probably got a defective junkyard TB and swapping out that casing fixed whatever problems you were having with it before.
FunctionSpec is offline   Reply With Quote
Old 03-09-2009, 07:16 AM   #16
that's another possibility, but it would be interesting if you could look at the model number on yours, to test WolfWings' theory!
Old 03-09-2009, 08:12 AM   #17
yarstar
That is it. I bought it from this guy here in Georgia. Really straight up guy and the price was way lower than what I found elsewhere. They get all there parts used off of totaled cars. Back in January when I got mine, he said he had 4 more.
Old 03-09-2009, 02:37 PM   #18
mikenacarato
SIPNDEW
Drives: 15 STI
Originally Posted by gwasabi View Post
no CEL over 100 MPH
lol i didnt mean 100mph, i meant 100 miles of driving
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
