Old 04-15-2009, 10:53 PM   #1
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers
For sale is a 1ZZ throttle body I previously had installed on my car. The throttle body is in very good condition and worked fine however I did encounter oscillations at idle. I did not use gasket maker to properly seal the throttle body and I am almost certain this is why I had experienced oscillations. I have cleaned both the valve and the cylinder of the throttle body, removed all of the epoxy over the idle set screw, and drilled out all of the rivets attaching the throttle body chip. Included are the 1ZZ throttle body, the 1ZZ throttle body chip, and the hardware holding the chip in place. Buyer will just need to drill out rivets on the 1NZ throttle body, place the 1NZ chip on the 1ZZ throttle body, and apply gasket maker.
Price is set at $55 shipped in the US using the USPS.
Also for sale is a pair of 0.25" aluminum wheel spacers. I used these on my car for approximately four months but with my tire/wheel/suspension set up, they cause occasional rubbing. Both are in very good condition, not warped, cracked, or pitted.
Price is set at $20 shipped in the US using the USPS.
Interested parties please PM me.
1ZZ throttle body shown on left, 1NZ throttle body on right.
Wanted: Forced Induction
m911gt is offline
Old 04-18-2009, 05:27 PM   #2
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
Prices reduced!
m911gt is offline
Old 04-18-2009, 06:13 PM   #3
YarisSedan
YarisSedan's Avatar
Drives: 08 Yaris Sedan
Do you need to use stud extenders with this wheel spacer if not ill get em
YarisSedan is offline
Old 04-22-2009, 11:15 AM   #4
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
I apologize, I did not see this post until now (darn school). NO you do not need longer studs, they will work with stock studs. :)
Please pm me if interested or if you have any more questions. Thanks
m911gt is offline
Old 04-22-2009, 01:00 PM   #5
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
wheel spacers SOLD
m911gt is offline
Old 04-23-2009, 07:56 PM   #6
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
Bump for the TB :)
m911gt is offline
Old 04-25-2009, 08:52 PM   #7
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
TB sold!
m911gt is offline
