Old 09-08-2010, 07:28 PM   #91
dbielawski
Drives: 07 Yaris
I was about to say that you need to get your eyes examined in regards to the 2 vs 3 pins on D3, but then I took a look and noticed that on my 08 there are indeed only 2 pins on the clockspring side of that connector.
The other pin for the cruise control is ground. You can simply tie the other wire to the frame of the steering wheel, since it is a chassis ground.
Ok...now what? Mechanic grounded the cruise stalk. When cruise stalk pushed to activate, the ABS, parking brake and PS lights came on but cruise still not working!!!
Any suggestions. Thanks!
dbielawski is offline   Reply With Quote
Old 09-08-2010, 08:17 PM   #92
I hate to say it, but perhaps have someone else do the work. Many forum members, who are not mechanics, have done this mod without an issue.
Based on the lights that came on, I would say at this point that your mechanic has the ECM pin in the wrong position.
Old 09-10-2010, 08:10 PM   #93
dbielawski
Drives: 07 Yaris
You are correct. Cruise at last!
Old 09-15-2010, 01:38 AM   #94
daveprue
My Pride & Joy...
daveprue's Avatar
Drives: 2010 Yaris 5 Door LB
Easy Install
I have a 2010 5dr Liftback w/auto trans.
Per the Forum DIY, I used the following parts, ordered from ToyotaPartsZone.com:
84632-08021 Switch, Speed Control: Quantity 1 @ $78.89
84633-02020 Wire, Cruise Switch: Quantity 1 @ $27.93
45184-52130-B0 Cover, Steering Wheel: Quantity 1 @ $22.60
90159-50199 Screw, W/Washer: Quantity 2 @ $0.73
Installation took 20 minutes (taking my time). Works flawlessly.
After installing, I found this switch on ebay for $19.99 plus $10 shipping. Can't tell if the wire is included or not.
daveprue is offline   Reply With Quote
Old 09-16-2010, 02:49 PM   #95
little_samba
Drives: Toyota Yaris LINEA SOL
Cruise control on European Yaris
Hi everyone,
I want to hear the confirmation again. I read the thread and somewhere it is said that a European Yaris 09 cannot install cruise control using the method described above, is it true, and in that case, are there any other ways to install it myself without getting to dealer (who would ask for more than 500 Euro). Thanks in advance.
little_samba is offline   Reply With Quote
Old 09-16-2010, 03:39 PM   #96
Originally Posted by little_samba View Post
Hi everyone,
European ECMs definitely don't have the OEM cruise control.
Check out the link below. This Belgium based company makes an aftermarket CC for European Toyotas:
http://www.el-pas.com/products.htm
Old 09-16-2010, 04:08 PM   #97
little_samba
Thanks, CTScott for your quick reply. I followed the link, and it is quite amazing to see such a product exists (donot know the price though). As there are differences between European models and American ones, regarding the mods to the car (to increase performance and stability), which one do you think is the most do-able ones? (rear-sway bar, SSK, strut bar...?). Thanks in advance.
Old 09-16-2010, 04:31 PM   #98
All of the mechanical mods (sway bars, springs, etc.) are compatible between American and European Yaris.
Old 09-16-2010, 06:10 PM   #99
little_samba
Regarding the SSK, how can I check if my Yaris 2009 is compatible?
Old 09-29-2010, 07:00 PM   #100
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Originally Posted by FunkyCole View Post
I would just like to add, Disconnect your battery before you mess with your airbag.
I'll add... It's not the airbag you have to worry about (there are FAR too many fail-safes.)
It's eletrocuting yourself with the electric horn spade connector.
As me how I know...
Old 09-29-2010, 08:11 PM   #101
As me how I know...
YIKES!!!!! The airbags don't actually have fail-safes. You just give them 12V and they go BOOOOOOOOM!!!!! The SRS system has fail-safes to prevent accidental deployment, but the airbags are just simple explosive charges. To dispose of an un-popped airbag, you simply apply 12V to make it pop (with the airbag contained in a stack of tires for safety).
Old 09-29-2010, 09:31 PM   #102
firemachine69
Well yes, but those connectors are hidden by rubber. Unless you're doing something worthy of a Darwin award, they will not magically receive receive twelve volts of power. (Unless your engine is running, coasting downhill, and happen to be stopped by a wall. )
Indirect heat doesn't set them off, either. Mechanic cut a stripped torch off the airbag in my Sunfire. We all gleefully awaited a BANG in the waiting room. Alas, only a bill for a half hour's worth of labour.
Old 10-02-2010, 03:16 AM   #103
the.family.car
+ 2006 CSM Scion tC
Drives: 2010 Flint Mica Yaris Sedan
Send a message via AIM to the.family.car
so i bought a 2007 scion xb steering wheel off ebay. won it in a bid for $9.99 with free shipping. came with the switch and the harness. just installed it. works like a charm.
2010 yaris sedan automatic with the power package so it was straight plug and play.
$9.99!!!
the.family.car is offline   Reply With Quote
Old 10-02-2010, 08:23 AM   #104
Revsson
Sounds like a nice deal there the.family.car!
Old 10-03-2010, 02:44 AM   #105
the.family.car
+ 2006 CSM Scion tC
correction it was a 2008
thanks
automatic transmission w/ power package
oem floor mats
diy oem cruise control
Old 10-20-2010, 05:49 PM   #106
10yaris10
Drives: 2010 yaris
FYI for everyone according to my local Toyota parts dept those part numbers are for a 2008 yaris.... Also my dealer said there was no "kit" also. Guess it's time to show them this thread and school the boys!
10yaris10 is offline   Reply With Quote
Old 11-07-2010, 08:17 PM   #107
3dr5speedblk
StickShift
3dr5speedblk's Avatar
Drives: 2010 Yaris HB
Waiting for parts!
2010 3door in the driveway, Black w/ 5speed
power PKG, mats, Tinted back 3 windows
putting CC on as soon as i get the parts!
Great DYI it will make the install EASY!! saved me $$$!!
3dr5speedblk is offline   Reply With Quote
Old 11-23-2010, 08:25 PM   #108
ibanezjeepguy
Drives: 2010 Meteorite Liftback
you wont be schooling anyone because there is no kit... just a bunch of individual parts bought and installed to make a function work.
ibanezjeepguy is offline   Reply With Quote
How difficult is it to install the aftermarket cruise control kit? grampi Performance Modifications 3 07-19-2007 08:06 AM
