Old 06-04-2011, 03:36 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
FYI cam gear
I went and changed my serp belt and just by doing that re screwed up the cam gear set up again. It cost me 500$ to fix it 6 months ago.
If you have an 07 and you have trouble with code p00011 or p00012
dont believe the dealer if he tells you you have to replace the cam gear.
You DO have to take it out and re install it properly and will need an air hose
and small point nozzle to set a pin properly but you can fix it and the whole fix can be had from under the valve cover. You Dont need to take any other stuff off. The instructions are available on the web or on the service bulletin for the 07 cam gear problem. Dont know if other years are bad too.
I havent fixed mine this time.... I think the Yaris is heading for the junk yard.
Tired of this tin can with 230K on it.
yaris9876 is offline   Reply With Quote
Old 05-25-2012, 05:09 PM   #2
yaris9876
http://www.youtube.com/watch?v=OtRlQ...eature=related
Old 05-25-2012, 06:48 PM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
At the very least, give us a chance to scavenge it first! =)
JUN Releases Camshafts for the 1NZ-FE changchewsoon Performance Modifications 53 01-23-2017 08:28 PM
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 01:30 AM
2006 Yaris 1.3 TR, 80k miles- Clutch need pressing to its end OR Gear change getshard planet DIY / Maintenance / Service 0 08-15-2010 10:20 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
New Owner - Lights on Gear Shift javagirl New YARIS Purchase Forum 8 05-22-2009 02:23 AM
