Old 03-08-2012, 06:34 PM   #1
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
Front Passangerside wheel bearing
Do i need to remove ball joints and steering joints and 2 bolts holding shock to remove wheel bearing?
yaris4062007 is offline   Reply With Quote
Old 03-08-2012, 10:05 PM   #2
Yes
Old 03-08-2012, 11:48 PM   #3
yaris4062007
Thank you scott, how do i remove the ball joint and steering joint does it pop out after removing the bolt or do i need to use special tool.
Old 03-08-2012, 11:51 PM   #4
yaris4062007
I got a quote from pepboys $330.00 for labor. 2.8 hrs.
$60.00 toyota wheel bearing.
Old 03-09-2012, 06:13 AM   #5
Check out the "Axle" section of the service manual, which you can download from Micro Image:
http://www.microimageonline.com/foru...32-YARIS-FILES
Old 03-09-2012, 01:34 PM   #6
yaris4062007
Thank you scott ;)
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Undercoating Your Inner Wheel Wells - How To ! Chris07LB Cosmetic Modifications (Exterior/Interior) 46 08-10-2012 11:17 PM
Front Driver Side Wheel Chirping Hard_Yaris DIY / Maintenance / Service 5 06-29-2010 04:38 PM
