Old 04-01-2014, 05:34 AM   #1
bkj150
Drives: 2008 sedan
Exclamation After changing the brake shoe some sounds are coming from wheels shile running
Friends,
I went to a tire changing shop to rotate my tires for adjusting wear and tear,that time they informed me to change the brake shoe, because it is nearly finish.So I changed the brake pads.
After changing the brake shoe some sounds are coming from wheels while running on low speed.
I came back to the workshop and checked the wheel, but they are telling the sound because of new pads, later it will go.
But later also no change.
So what will I do?
Regards,
bkj150 is offline   Reply With Quote
Old 04-01-2014, 06:36 AM   #2
If the noise is a scraping sound, then they probably did not adjust the shoes properly and they are rubbing on the drums more than they should. If you jack up the rear and spin the wheels they should not have resistance. If they do then they should be readjusted.
brake, brake problems, wheel, wheelnoise
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
Parking Brake Shoe Adjustment bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-14-2009 02:26 PM
