Old 03-20-2015, 11:20 PM   #1
xdarkxfirex
Drives: 2015 yaris le
Strange Whistle Sound at Idle
Bought a 08 yaris base 1.5l last year.
My old belt was replaced like two months ago with a bando, and it worked fine. Last week I replaced the waterpump and coolant because the bearing was bad. I noticed the car had an intermittent whistle/whining sound for a while. I think I've only noticed it once while driving. Today it was driving me crazy and I looked anywhere where there was vacuum hoses, used soapy water, and nothing. I only really notice it on idle. The only possible thing I would think is the alternator bearing. What do you think?
I noticed between the head and the block, some burned oil. I hope it's not the head gasket
xdarkxfirex is offline   Reply With Quote
Old 03-21-2015, 07:52 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Um, soapy water is not how you find a VACUUM leak. That's how you find PRESSURE leaks. You need to use starter fluid, or propane. As you spray each connection listen for the RPMs to rise. You can use a propane torch too. Just open the gas and put the tip around each joint. Make sure you're outside.
Old 03-21-2015, 08:01 AM   #3
nortonfb
Drives: 2007
You can use WD40. Propane doesn't sound safe if you have a spark some
where that is exposed. I know it's not likely but I have dealt with gas issues.
Also went to HVAC class and saw people without eyebrows.
Norton
nortonfb is offline   Reply With Quote
Old 03-21-2015, 08:07 AM   #4
Bluevitz-rs
Propane is an actual method used by mechanics.
diy, problem, sound, whine, yaris
Whistle at idle - vacuum leak, induction side RichieRoo General Yaris / Vitz Discussion 17 12-16-2022 05:53 AM
Strange creaking sound whenever applying brakes at stop position. YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-04-2015 04:51 PM
1.33 engine strange tapping on idle dobrik Third Gen Yaris General Discussion 7 10-31-2014 07:26 AM
Strange sound during ignition mikastefh General Yaris / Vitz Discussion 0 06-13-2010 03:58 AM
strange sound when i begin to accellerate? davembfan General Yaris / Vitz Discussion 11 06-06-2007 03:31 PM
