Old 06-06-2016, 04:07 PM   #91
Sorry, I meant lower FD... I want to say 3.9
Old 06-06-2016, 06:55 PM   #92
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Old 06-28-2016, 08:20 AM   #93
Is there a good/easy way to swap out 5th in an echo for something that'd net lower highway rpms? Will the 0.729 from a c60 fit in a C150 from an echo?
Old 06-28-2016, 09:06 AM   #94
Bluevitz-rs
I'm not sure on that one. The Echo already has the lowest highway RPM I'm pretty sure with its .815 5th and 3.5FD
You'd have to see if there's any 5 spd gearboxes with the lower 5th. I think the spot where 6th goes is a different Ø
Old 06-28-2016, 09:26 AM   #95
C53 and c59 have .725 5th gears...
Old 06-28-2016, 09:58 AM   #96
Bluevitz-rs
Chances are pretty good that it'll fit, but you won't know for sure until you're holding them both in your hand.
Old 07-04-2016, 06:30 PM   #97
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
This is an awesome project and I bet it is a blast to drive! But after doing the gear shift drop calculation, you can see the 6600 redline will lead to a LOT of shifting.
ArmstrongRacing is offline   Reply With Quote
Old 10-01-2018, 11:22 PM   #98
Gorilla
Gorilla's Avatar
Drives: Vitz & Supra
Hi Guys,
Im thinking about buying a C160 with Factory LSD from the AE111.
My Echi is equipped with the C154, but noted BlueVitz you had the C150??
Also is your dash Digital? Any issues with that?
I was looking for a C56 from the Japanese Vitz but they seem harder to find!
Gorilla is offline   Reply With Quote
Old 10-02-2018, 06:22 AM   #99
Bluevitz-rs
Originally Posted by Gorilla View Post
Hi Guys,
My Echi is equipped with the C154, but noted BlueVitz you had the C150??This shouldn’t make any difference. All C series bell housing are interchangeable.
Also is your dash Digital? Any issues with that?No, I have the analog dash with tach.
What chassis are doing the conversion in?
Old 10-03-2018, 09:47 PM   #100
saikouguy
Drives: Toyota Echo
He has an Echo like yours NCP13 Australian Model
saikouguy is offline   Reply With Quote
6 speed, conversion, gearbox, transmission
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 467 10-18-2022 10:20 AM
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
