Old 12-05-2018, 10:14 AM   #1
tmontague
tmontague's Avatar
Rear brake shoe advice needed
I'm looking for advice on what rear brake shoe compound I should run for next track season. I have carbotech xp10's up front and love them and I'm a big fan of carbotech's customer support. I have been using stock rear shoes and they have held up pretty good but are now almost completely worn.
Carbotech recommended u run xp8's in the rear for the track with my set up of 80tw tires and the weight of my car. Problem is, these are one off's to make and cost $240 a pair regardless of what compound I go with.
My question to those who track and even autox their cars is, did you notice a large difference going with a track pad in the rear over the oem compound?
I'm trying to figure out if it is worth the $ to go with track shoes or not.
I dont know is Jason still goes on this forum or not but I'm curious as to what he ran in the rear.
I am far from a pro driver but I do 45 min session at a time and I brake super late and drive the crap out of the car at the track. To put it in perspective hawk hps pads lasted half a lap on my first hot lap and they never recovered
Thanks
Old 12-05-2018, 12:06 PM   #2
Steve35
Steve35's Avatar
Drives: 2008 HB
I'd call the guys at Porterfield, they are the one that helped Jason.
https://www.porterfield-brakes.com/
Steve35 is offline   Reply With Quote
Old 12-05-2018, 12:21 PM   #3
tmontague
tmontague's Avatar
Thanks, I'll contact them
Old 12-05-2018, 03:15 PM   #4
Jason@SportsCar
Thanks
Never had any call to upgrade the rears. The OE shoes already give inside lock up when trail-braking into very fast turns, a more aggressive pad would only make it worse. When the inside tire lifts and the brake pedal has even a little pressure on it that tire just wants to stop.
I know some of the B-Spec guys (they have ABS we don't in H Prod) found that too much rear brake put the car in ice-mode.
Still have the original rear shoes on the car after four seasons.
HPS is a street pad, not a good choice for the front for anything other than autocross. We have Porterfield cut out a Hawk DTC-60 for the front of the Yaris.
Old 12-05-2018, 05:08 PM   #5
Track or no track, I've never heard a case for anything other than OE.
Old 12-05-2018, 05:33 PM   #6
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
what is ice mode, good thing i have a tCS; VSC off button.
DarkShadowFox is offline   Reply With Quote
Old 12-06-2018, 06:40 AM   #7
tmontague
tmontague's Avatar
This is exactly the info I was looking for - thank you Jason. Carbotech warned me that it could upset the braking balance. If the oem shoes last throughout your season then I'll stock with that. Saves me the cash to put elsewhere.
I agree with your on the HPS pads, they were what u had when I started tracking the car but as I started to work on brake zones and threshold braking they fell apart very fast. Now I just use them for dding and they are fine for that.
I know what you mean about "ice mode". TMP has a chicane right before a 90 degree corner and if I apply the brakes a few feet too early I do so during a bump and I completely blow the corner - the abs will kick in on all 4 wheel for the next 4 seconds making my brakes useless.
Hiss or pfft when pressing brake pedal kwk442 DIY / Maintenance / Service 3 06-03-2017 06:10 AM
Advice on wheel spacers and sway bars needed! Lars Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 12-05-2013 11:28 AM
Yaris/Echo Rear Brake Question pdarnell DIY / Maintenance / Service 2 08-21-2007 01:15 PM
Rear brake proportioning valve??? PetersRedYaris DIY / Maintenance / Service 16 03-25-2007 11:10 PM
