Old 02-23-2024, 04:19 PM   #1
snowblower
Drives: 2014 Yaris LE, France built
PCV valve preventative maintenance
Is there a consensus on preventative maintenance of the 1NZ-FE PCV valve? Clean only? Replace? Never a problem, forget about it?
snowblower is offline   Reply With Quote
Old 02-23-2024, 04:28 PM   #2
komichal
On 2SZ-FE I just pop it out like once a year, spray through it with brake cleaner and try to blow air through it - it should go easily one direction and it should not go at all in the opposite direction. If that is the case then it can be safely placed back.
Old 02-27-2024, 10:49 AM   #3
Billiam
Drives: '10 White Yaris 4D LB
Not worth the hassle. It's a $10 part from your local dealer. Replace it.
If you want to enjoy your car, stay off of the internet.
Old 02-27-2024, 11:44 AM   #4
snowblower
That's what I've always done for my Hondas. This is my first Toyota. I may just do that. We'll see. I'm trying not to break the parts bank with this car.
Do you happen to know if there is a spring in Toyota's PCV valve for the 1NZ-FE, or just a simply check valve? I'm more inclined to replace PCV valves that have a spring due to the spring relaxing with age.
Old 03-01-2024, 10:44 PM   #5
Billiam
It's been 2 or 3 years since I replaced it and frankly don't remember. But I'm fairly certain it's just a check valve. There just wasn't a significant price difference between aftermarket and OEM....especially when you're taking about a $10 part.
Old 03-07-2024, 02:49 PM   #6
esse10
Drives: 2009 yaris 2 door
clean
once a year just remove, clean with denatured alcohol or contact cleaner and put back.
esse10 is offline   Reply With Quote
Old 03-07-2024, 07:11 PM   #7
alanwagen
How easy is it to get to though? I can't find it. 2015 Yaris 1.5l L
Old 03-16-2024, 12:11 PM   #8
snowblower
I took mine out finally. I cleaned it with brake clean. Sprayed it and let it soak in cleaner for a while (my wife will never know what that egg cup was used for). It was leaking a bit of reverse flow before cleaning. Leak free after cleaning. The service manual just says it should flow in one direction freely, not flow at all in the other direction. I'm going to leave it at that. Also, there is a spring in it. I can see it in the service manual diagram and I can tell when inspecting the physical valve. The inlet side of the valve will depress easily and spring back to its original position, if anyone cares to see for themselves.
Old 03-16-2024, 12:12 PM   #9
snowblower
In my 2014 with a 1NZ-FE engine, it's at the back right of the engine at the corner of the valve cover. You have to remove the plastic engine cover to get at it.
Old 03-16-2024, 12:17 PM   #10
snowblower
Finally, the service manual says 27 N-M, 20 ft-lb. It also says "precoated part". Which I expect means thread sealant. So I'm reinstalling mine with Permatex High Temp thread sealant.
Old 03-16-2024, 12:50 PM   #11
snowblower
Don't follow that 20 ft-lb blindly. The "precoating" on the factory part is probably dry. With a liquid sealant it will be lower. I put a torque wrench on it out of curiosity. I wasn't conformortable going beyond about 15 ft-lb. It was very snug.
PCV VALVE THREADS DANIELTNIEVES DIY / Maintenance / Service 3 08-17-2015 03:11 PM
Preventative Maintenance tmontague DIY / Maintenance / Service 20 11-05-2014 12:22 PM
PCV valve over tight peewee1 DIY / Maintenance / Service 8 09-01-2013 09:28 PM
PCV Valve Replacement devinlamothe DIY / Maintenance / Service 27 03-16-2013 11:06 PM
