Old 10-25-2008, 07:09 PM   #253
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
o ok i just want the crank pully tho
Yoda is offline   Reply With Quote
Old 10-25-2008, 07:41 PM   #254
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
he sells them for 112 free shipping on his website
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-26-2008, 04:54 AM   #255
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Originally Posted by jronald View Post
INFO for Thailand Yaris:
The alternator pulley is different than US version.
The rest is sooooo goooood!
So much better for throttle response and engine REV up.
(I've post it before and I don't mind posting it again now)..
NST FTW!
Does that mean the NST Alternator pulley won't fit? Did you buy the 3-pulley kit but was only able to fit 2 of them?
Leong's NCP91 Toyota Yaris E
Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38
Stebel horns, Philips Silvervision turn indicator bulbs
TTE Lowering Springs, Camber bolts
TRD Blue brake pads
Fujitsubo Super Wagolis axleback exhaust
DC Sports header
cleong is offline   Reply With Quote
Old 10-26-2008, 10:00 AM   #256
Correct, sadly
Old 10-26-2008, 11:30 AM   #257
ZING
ZING's Avatar
Drives: Yaris '09,GTi '09, BMW 3.30ci
I saw a couple of comments asking how this would work on an automatic, but I didn't see a satisfying response yet.
I bump this question.
ZING is offline   Reply With Quote
Old 10-26-2008, 02:27 PM   #258
battleversiontc
i let you know by today i have to install it on my gfs car which is an automatic
Old 10-26-2008, 02:33 PM   #259
ZING
ZING's Avatar
Excellent, thanks
Old 10-26-2008, 05:22 PM   #260
NonStopTuning
Gains are very similar on both auto and manual cars. Weight reduction is very noticeable, and the principle of underdriving also applies equally, regardless of transmission type.
We have done A LOT of testing with automatics, and gains have always been there across the entire RPM band.
MIKE @ NST
www.NonStopTuning.com
Old 10-26-2008, 11:45 PM   #261
battleversiontc
Originally Posted by Galavoxx View Post
Engine braking is a little better but is negligible. I have no idea about the auto. Anyone care to comment on the auto?
engine braking is still the same no change it actually was noticable just with the intake that add alot of engine braking but the difference is noticable on the auto but the engine braking is more back to stock i have all three pulleys. but love it going up hill is like butter now. exhaust and headers are next then ill work the suspension after
Old 10-27-2008, 12:00 AM   #262
jronald
jronald's Avatar
Drives: Black NCP91R
YUP..
Now it's only good for paper weight. I've tried to sell it to Swift owner (it seems could work with that alternator).. but so far, no luck.
jronald is offline   Reply With Quote
Old 10-28-2008, 09:58 AM   #263
lamdog
Drives: Yaris YRX
received a underdrive pulley from Gram today..
tried to fit it, but no luck... the bolt is freaking hard.
i have also tried an electric drill to take it off, the bolt did not move at all.
sighs... gonna take the pulley to my mechanic this weekend, i cannot wait....
lamdog is offline   Reply With Quote
Old 10-28-2008, 11:05 PM   #264
battleversiontc
yeah i had to use an impact gun to remove the bolt for the crank
and a 10mm wrench for the water pump pulley along with a thick srew driver through the holes to loosen the water pump pulley bolts and i just impacted the alt pulley it was all good after that
Old 10-31-2008, 08:32 AM   #265
lamdog
Drives: Yaris YRX
got my underdrive pulley on today...
took it to my mechanic, it was just a piece of cake with air tool....
i could notice that the throttle is much lighter right after the pulley was on...
no unusual vibration after.
Old 11-05-2008, 12:28 AM   #266
NonStopTuning
Thank you sir
MIKE @ NST
Old 11-06-2008, 01:11 AM   #267
battleversiontc
im waiting to find out the differences with the mpg on these i hope to see alot of improvement on this since now i dont really push the gas down as much now
Old 11-20-2008, 04:03 PM   #268
NonStopTuning
Originally Posted by richardholdener View Post
Here are the official results of an honest back-to-back dyno test of the NST pulleys (crank, alt & WP). Car was run on the dyno with stock pulleys and then we swapped out the stock pulleys for the NST (I believe 10% under driven) though sizing on WP and Alt looked the same. Pulleys were definitely worth some power as indicated by grpah. Note also the power numbers (123 wheel hp) is a new NA record-posted elsewhere with description of mods.
Thanks again Richard, your hard work and dedication is much appreciated
Old 11-20-2008, 07:35 PM   #269
*MAD DOG*
*MAD DOG*'s Avatar
Is that dyno a stock car vs the same stock car with stock pulleys removed and NST pulleys (including 10% underdrive)? Were there no other engine/exhaust mods?
Old 11-20-2008, 07:41 PM   #270
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
One with pulleys and one without thats about 3hp!
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
