06-13-2010, 01:52 AM | #1 |
Drives: 2009 Meteorite 3dr Join Date: Jul 2009
Cruise Control Went Out Tonight... Please help.
On my way home from work tonight (1 hour commute each way) I noticed I could not get my cruise control to do anything. This is stock cruise control for my 09 yaris hatchback that I use almost everyday. I messed with it for quite a while and could not get it to engage at all.
Where do I need to begin to look for the problem?
Touchscreen DVD Navigation - 10" Bazooka Subwoofer - Kenwood Speakers - Toyota Premium Horn set AFE Pro Dry Air Filter - modified air intake box - 1ZZ-FE Throttle Body - Ultra Racing Rear Sway Bar & Front Strut Bar NST in cabin & engine bay SSK's - TWM shifter base bushings & cable bushings - Megan Racing C-Pillar Brace |
06-13-2010, 08:45 AM | #2 |
Drives: Yaris HB Join Date: Jul 2007
Are your brake lights on while you're not pushing the pedal?
06-13-2010, 09:54 AM | #3 |
toyota
check for blown fuse..
06-13-2010, 06:53 PM | #4 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Is it factory OEM (stalk on right of steering wheel) or Dealer OEM (AKA Rostra - stalk on left side of steering wheel)? That will make a huge difference in direction for troubleshooting.
06-14-2010, 02:52 PM | #5 |
It's on the right side of the steering wheel. It appeared to me on my way home today that the cruise control works until I turn the headlights on... then nothing.
06-14-2010, 03:08 PM | #6 | |
I would check the following (in order based on ease of access): 1. Stop lamp switch (on the top of the brake pedal arm). Make sure that it isn't triggering too easily (jostle the brake pedal, while having someone watch the taillights). 2. Clutch switch (on the top of the clutch pedal arm). Make sure that is staying triggered, until the clutch is pressed. It's mount is adjustable, so make sure it hasn't loosened up and backed out a bit. 3. Fuses - Check STOP and ECU-IG (in the under dash fuse panel). 4. Finally, check the cruise control/horn connector on the steering column to make sure it is seated properly and that the pins for blue and brown wires are nicely seated (the connector is next to the headlight stalk one with a black, brown and a blue wire). |
06-14-2010, 04:31 PM | #7 |
is the top of these pedal arms gonna be under the hood or inside the car?
06-14-2010, 10:03 PM | #8 |
Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
Inside the car. One example would be in this DIY pdf file page 4:
DIY Cruise Control by Vince87 Or this one: http://www.yarisworld.com/forums/showthread.php?t=23510 |
06-17-2010, 10:46 AM | #9 |
it is the rear bulbs( driving light). I had the same problem, the system can tell if a bulb is out that is why it will work with the headlights off.
06-17-2010, 10:56 AM | #10 |
Hmmm... I changed out the bulbs to LED's and it thinks the bulbs are out. That's dumb cuz I know they're not out... What to do now...
06-17-2010, 11:36 AM | #11 |
Actually, the two taillights and the 3rd brake light are all paralleled together, and the ECM doesn't have an input for measuring the current draw to detect a bulb being out.
What have you checked so far? |
06-18-2010, 02:19 PM | #12 |
i had switched to leds and the cruise stopped working as soon as i went back to standard bulbs it worked fine. I can't tell you why but that is my experience?
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Cruise control install 2009 Yaris 3 door | PeteZNY | DIY / Maintenance / Service | 125 | 03-31-2024 09:22 AM |
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 467 | 10-18-2022 10:20 AM |
Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
