09-18-2012, 02:03 AM | #1 |
The Flying Tomato
Drives: 2009 Red Yaris Hatchback Join Date: Dec 2009
Fog Light Install Question - Should Be a Piece of Cake for YarisWorld Veterans
Hey Ya'll,
I recently bought an Ebay Foglight Kit, and the installation was going alright until I encountered a wiring issue. After searching the realms of the internet, I only found one person with the same problem, but for a Toyota Sienna; I couldn't find a solution which I understood from that: http://www.toyotanation.com/forum/27...fog-lamps.html From the picture in the link above, I don't know where the brown clip and white clip connections go. I am absolutely dumbfounded regarding those two wires... Any help would be greatly appreciated! I have a 2009 Yaris Hatchback (Base) |
09-18-2012, 10:59 AM | #2 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Did you get any documentation with the kit?
Although these kits are labeled as being for the Yaris, they really are not by any means designed for them, so the wire colors mean nothing unless there is some documentation on the purpose of the wires. I have seen a few different variations of these kits with different color wires. Also, these cheap kits are notorious for relay failures that result in melting of the relay housing and connector. I highly recommend rewiring the kit to use the OEM fog light wiring and relay, as the Micro Image kit does. The document below explains the process: http://www.microimageonline.com/down...h%20Wiring.pdf
09-18-2012, 01:26 PM | #3 | |
The Flying Tomato
Thanks for the MicroImage document! I've seen it many times before, but if I can't figure this wiring thing out, I may just end up going with the OEM wiring and relay option. |
09-18-2012, 01:53 PM | #4 |
The Flying Tomato
I found the same setup, but the installation is for a Honda.
http://www.v6performance.net/forums/...ights-diy.html What do you think? |
09-18-2012, 02:40 PM | #5 |
The Flying Tomato
So from the previous link, it appears that the red wire (white clip) gets spliced in with the parking light wire, and the white wire (brown clip) somehow needs to be routed to the battery...
I did find another Honda wiring example, though, and they have a brown female clip already built into the Honda...does the Yaris have something like this? (Second to last picture) http://www.8thcivic.com/forums/light...tall-pics.html |
09-18-2012, 02:54 PM | #6 | |
The Yaris does not have a mysterious hanging connector for that plug like that Honda happened to.
09-18-2012, 03:19 PM | #7 | |
The Flying Tomato
09-18-2012, 03:21 PM | #8 |
Look in the DIY section of the forum for my Remote Starter DIY for info on where to grab constant or ignition switched power right under the dash.
09-18-2012, 03:28 PM | #9 |
The Flying Tomato
Excellent, thank you very much! You've been a big help I'll let you know how it turns out!
09-19-2012, 05:08 PM | #10 |
The Flying Tomato
Sorry, I am a little new to this...where can I find the parking light wire under the dash? Thanks!
09-19-2012, 05:15 PM | #11 | |
The Flying Tomato
http://www.modifiedlife.com/2009-toy...-instructions/ Pin 29, correct? (Green wire) |
09-19-2012, 10:17 PM | #12 | |
http://www.yarisworld.com/forums/sho...y+remote+start My documentation shows pictures of the locations. If you are thinking of having them come on with your parking lights, then you will want to modify the harness per the Micro Image DIY. The way that the included harness is designed, you would connect the kit to ground and battery power (or to have it ignition switched you would use an extra relay connected to the ignition switched power wire per my DIY and would switch the battery power using that second relay).
09-20-2012, 03:18 AM | #13 | |
The Flying Tomato
-I connected the foglight power wire (white with brown clip) to the constant 12V source -I connected the switch illumination wire (red with white clip) to the parking lights. This configuration worked fine temporarily; the switch illuminated when the parking lights were on and the fog lights turned on when the switch was activated. However, when I put the plastic casings back into place, the parking lights had issues. They will not turn on, which in turn doesn't illuminate/power the switch, so the fog lights won't activate. Any thoughts? Does grounding at different grounding points affect anything? I checked the fuse, and it was still good. It seems like there may be an issue with the grounding or my tap splice with the parking lights... Thanks, you've been a big help! I greatly appreciate your patience with this! |
09-20-2012, 05:06 AM | #14 |
やりすぎだ~
If everything worked fine before you put the bezel and lights back in,
then most likely you accidentally pulled or pinched a wire or connection somewhere. You'll have to retrace your wires. Ground should be a solid ground - to the frame/body of the car would be ideal. |
09-20-2012, 07:42 AM | #15 | |
09-20-2012, 10:19 AM | #16 | ||
The Flying Tomato
I'm sure the red wire was to power the illumination switch; I was testing the connection throughout the installation, and when I wired the red wire to the parking lights prior to wiring the white wire with the 12v connection, the switch would illuminate without powering the fog lights. So that seemed as a check that it was wired to the correct points. |
09-20-2012, 10:30 AM | #17 | |
I would double check the TAIL fuse, as only that and the 120A ALT fuse are in circuit with the tails. Since they worked for a bit and then went out, the fuse may have opened less catastrophically than if it blew due to a short. The only other thing that may have gotten damaged is the T-LP relay, but that it integrated into the internals of the body ECU, so to replace it you would have to replace the entire under dash fuse panel assembly.
09-20-2012, 10:32 AM | #18 | |
The Flying Tomato
Tags |
diy, fog lights, installation, wires |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 09:47 AM |
Fog light jumping question | netz2008 | DIY / Maintenance / Service | 1 | 01-16-2012 10:55 PM |
Fog light install | 07yaris_fe | Cosmetic Modifications (Exterior/Interior) | 10 | 07-20-2010 02:18 PM |
question on Fog light | clfile | Cosmetic Modifications (Exterior/Interior) | 6 | 11-09-2006 08:11 PM |
rear fog light and tuned rear lights | lefti696 | Cosmetic Modifications (Exterior/Interior) | 0 | 11-09-2006 04:06 PM |
