Old 04-10-2016, 07:44 PM   #235
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
I received my RPM long-tube header, now To get this installed by May 2nd for the "one take" with Matt Farah.
ArmstrongRacing is offline   Reply With Quote
Old 04-19-2016, 02:14 PM   #236
i love it
side note: do you think the new corolla 6 speed would fit on your 2zrfe in your yaris engine bay?
by extension, would the corolla 6 speed bolt to a 1nzfe AND fit between the frame rails?
Old 04-19-2016, 06:44 PM   #237
ArmstrongRacing
Data doesn't lie
i love it
When we swapped the Xd 2zt/C50 into Computerlove's 09 LB, we used a big hammer to make room....so I would assume it would be the same procedure for any non-1nz power train
Old 04-19-2016, 06:45 PM   #238
ArmstrongRacing
Data doesn't lie
Here is last weekends autocross video!
http://youtu.be/ezT3yJ0fN20
Old 04-19-2016, 08:33 PM   #239
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Fun watch, thanks for sharing.
Old 04-22-2016, 02:04 AM   #240
froger
Drives: 08 yaris 1.8 dual vvti 5sp
No hammer needed when using a EC series 6sp transmission,the cases of the new EC 6sp transmissions are shorter,the length is about the same as the older 5 sp
c series transmissions.This is due to new case and gear design, Toyota went to a 2 piece case design.(c transmissions are a three piece case)
In Europe ,the yaris used a EC 6 sp on later generations of the 1.8 ts and 1.33.
froger is offline   Reply With Quote
Old 04-28-2016, 01:33 PM   #241
ArmstrongRacing
Data doesn't lie
Here are some pictures from my RPM long tube header install...
Old 04-28-2016, 01:36 PM   #242
ArmstrongRacing
Data doesn't lie
No way around it, the coating will get scratched upon install. I had to bend the bracket tab to get this in from underneath, and I also had to make a indent on the firewall for A/F sensor clearance
Old 04-28-2016, 01:39 PM   #243
ArmstrongRacing
Data doesn't lie
This is how my exhaust shop did my midpipe. RPM sent me an extra flange and gasket to make this a bolt-in header. I highly recommend installing a flex joint though, as I get a lot of vibration at idle with the a/c on...
Old 04-28-2016, 01:40 PM   #244
ArmstrongRacing
Data doesn't lie
This is my rear O2 sensor extension, this is required with the RPM header due to its length.
Old 04-28-2016, 02:21 PM   #245
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
Very nice.
brushforhire is offline   Reply With Quote
Old 04-28-2016, 03:11 PM   #246
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
True, but the EC uses a special throwout bearing with an integrated cylinder, which means your clutch system has to be changed to accommodate it. You could probably fab up your own lines, but I don't know if the US clutch master cylinder would work with the EU integrated throwout bearing/cylinder.
Old 04-28-2016, 05:10 PM   #247
Jeff Lange
Drives: 11 GSE21, 86 AE86
The ZSP90 used the same clutch master cylinder with the C56 and EC67.
If you bought an EC67 and it didn't come with any of the hydraulics, the following parts are what you'd need:
31400-59015 - Cylinder, Slave (with integrated release hub, includes bolts)
31407-52010 - Bleeder, Clutch Slave
91551-80820 - Bolt, Clutch Slave Bleeder (Qty: 2)
31482-52090 - Tube, Clutch (Slave to Bleeder)
31126-20090 - Boot, Clutch Tube
31482-52100 - Tube, Clutch Bleeder to Flexible Hose
90461-08567 - Clamp, Bleeder to Hose Tube
31484-52160 - Bracket, Tube to Hose (Transmission Side)
91671-80810 - Bolt, Tube and Bracket (Qty: 2)
90947-02G28 - Hose, Transmission to Body
Everything on the body side is the same between the C56 and EC67.
There are LH mount differences as well, however the RH/rear mounts are the same for C56 and EC67. The axles are the same between the two as well.
12372-37141 - Mount, RH Side
12325-37100 - Bracket, RH Mount
12351-37100 - Damper, RH Mount
Jeff
2011 Lexus IS350 6MT F-Sport with LSD
1986 Toyota Corolla GT-S Supercharged with TRD Stuff
2005 Toyota Yaris RS 5MT Short Track Car
Jeff Lange is offline   Reply With Quote
Old 05-02-2016, 09:01 AM   #248
CrankyOldMan
Jeff
Wow, that's awesome work!
Old 05-03-2016, 11:18 AM   #249
ArmstrongRacing
Data doesn't lie
So this happened...
Old 05-03-2016, 11:21 AM   #250
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Awesome. When does it air?
Old 05-03-2016, 11:55 AM   #251
tmontague
tmontague's Avatar
I've been looking forward to that video for a while! Let us know when it's put up
Old 05-03-2016, 12:07 PM   #252
ArmstrongRacing
Data doesn't lie
I think it takes a week to air, I'll keep you guys updated. It was so awesome, he made some bold statements about how fast the car is through the canyon!
unusual engine swap CoryM Performance Modifications 26 10-09-2015 12:17 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
Scion/Yaris engine swap mrrock Performance Modifications 1 03-02-2011 06:56 PM
