![]() ![]() ![]() Drives: yaris hatch 07 640K original m Join Date: Mar 2007
clutch replace
If you do a clutch replacement...you have to remove both axles from both the left and right
front assemblies..yes?? |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
Technically you don't have to, but it is best to remove them so they aren't interfering.
Remove from transmission
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
have any of you been inside a manual trans for the yaris??? like a rebuild of the gears etc..?
it's pretty much the same as any 5 speed transaxle make in the last 30 years.
what's your question? is it, "can you rebuild gears?" cause the answer is no. damaged gears need to be replaced. |
Thread Tools | |
Display Modes | |
Getting Rid of the infamous Clutch "Shudder" | tmontague | DIY / Maintenance / Service | 14 | 07-08-2023 01:56 PM |
Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 10:42 AM |
Aftermarket Clutch Q's | tmontague | Performance Modifications | 5 | 03-05-2016 04:33 PM |
Unique Smell from Air Going Through AC Blower | EddieCabael | DIY / Maintenance / Service | 30 | 01-19-2015 09:08 PM |
need help on my 2008 yaris compress clutch | susucosp | DIY / Maintenance / Service | 0 | 05-15-2014 03:48 PM |
