Old 12-09-2011, 12:20 AM   #127
"yaayyyy!"
Old 02-16-2012, 04:37 PM   #128
maxthehax
maxthehax's Avatar
Drives: Echo HB Turbo 6Speed
I understand you so much Lol!
People can say what they want, but I dont think the kit is cheap. People who say things like that have never really experienced what it is to put a turbo on a uncomom car! There is always a little something to tweak, and only with time you will fix every little things. But you need to live them before!
I have my own turbo kit that I run for about 6 months now, with only a base tune on Aem FIc. And still now I have never really feel the real potential on the car because I cannot... First of all I put a too small turbo 2 times! and now waiting for the good one (well I think this time is good!)...
Anyway, not gonna write all my life :P Just wanna wish you a good luck!
maxthehax is offline   Reply With Quote
Old 11-21-2012, 01:26 PM   #129
Focus_Sh1ft
Focus_Sh1ft's Avatar
Updated this also. It's been 2 years and four months now and things are going quite well. Here are the problems I've had with the kit so far
-Oil return. Tapping the block proved to be the better option
-BOV. Quality is questionable and I would recommend an aftermarket one.
-Actuator broke. Replacing it was easy and only $20. Finding the right size bracket can be tricky though.
-Downpipe weld gave out. Local mechanic welded it back up same day free of charge.
-Worm-gear clamps are sub-par. I had a crap ton of leaks coming from the couplers as a result. I'd recommend replacing them with t-clamps.
-One of the clamps actually sheared a hole in my AC line (down by the radiator/ac compressor). This can probably be attributed to user error.
Old 11-21-2012, 01:43 PM   #130
whoa. Thread revival. I miss my tC.
Old 11-22-2012, 02:33 PM   #131
Focus_Sh1ft
Heya Garm!
You'll be happy to know the tC is in GREAT condition. I definitely commend you for building such an amazing car. She's currently sleeping in the (heated) garage for the winter, but come spring she'll be spending a decent amount of time at the track I hope.
I'll do some updates in the spring. I also need to make an attempt to get back into the community here... Glad to see some more people have turboed, but let's be real - there needs to be many more turbo yaris owners!
BTW, I'm going to need some "goodies" from you in a few days.
Old 11-22-2012, 04:01 PM   #132
^ Happy to accomodate! and GREAT to see you online again.
Old 11-23-2012, 12:40 PM   #133
kou
Drives: 08 lb
Focus_sh1ft we will have to do a turbo yaris meet when I get mine finished.
Old 04-11-2013, 11:19 AM   #134
jb1
Drives: 2010 Toyota Yaris Hatchback
yo
this thread was sofa king helpful mane. how much HP did you get out of this ???????
jb1 is offline   Reply With Quote
Old 04-30-2013, 11:37 PM   #135
TheEggYaris
TheEggYaris's Avatar
Drives: White Yaris 3d Hatch
Focus I was wondering does the Boomslang Plug 'n Play Wiring Harness simplify this process at all?
TheEggYaris is offline   Reply With Quote
Old 05-01-2013, 04:42 PM   #136
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
You only currently have 2 options which will run you about the same amount of money which was proven by a member (CTScott):
1) Boomslang - breaks the heart and bank, but it is a plug and play which has different options for which management you use be it one of the piggybacks or a standalone. You essentially are injecting the PnP harness in the middle of things with certain wires either tapped or intercepted for signaling. The ends on the harness have male/female where required when it comes to plugging into the factory harness and the stock ECU. The BSlang also has a jumper to be able to run the car if needed without the management plugged in.
2) Custom Harness - time consuming and you had best have a lot of wiring knowledge.
Old 10-14-2014, 07:53 PM   #137
Martinezn.964
Drives: 07 Sedan S
hEY
Maybe i missed it but im curious how much hp have you gottn it on the dyno?
Martinezn.964 is offline   Reply With Quote
Old 01-02-2017, 09:02 AM   #138
joyahmed3244
Drives: toyota vitz 2011 RS GS
hey is it on cvt trans?? is it possible on normal cvt transmission with modding anything? i have a 2011 jdm gs vitz
joyahmed3244 is offline   Reply With Quote
Old 01-04-2017, 04:20 PM   #139
LeprKoRn
LeprKoRn's Avatar
Drives: 2012 Yaris YRS
Hey Focus,
I contacted Zage about the kit. I pointed out the fact (made no reference to you) that drilling and tapping of the block was required back when you fitted the kit in 2010 for oil return due to excess blow by. Apparently they use a different, larger hose setup now.
Do you think this would remove the issue you experienced?
Cheers
Lep
Sent from my SM-G920I using Tapatalk
LeprKoRn is offline   Reply With Quote
Old 07-07-2017, 01:26 PM   #140
bambam28
Drives: Yaris Hatchback 2012 SE
Bump!
bambam28 is offline   Reply With Quote
Old 04-09-2018, 08:44 PM   #141
Jerkratt
Jerkratt's Avatar
Anyone have the ability to re upload the pictures in this thread?
"It hurts more when its wet"
Old 04-10-2018, 03:27 AM   #142
No need???
http://yarisworld.com/forums/showpos...8&postcount=16
Old 04-10-2018, 07:29 AM   #143
Jerkratt
Jerkratt's Avatar
Perfect! Ty!
Old 04-10-2018, 02:43 PM   #144
Perfect! Ty!
No problem. I wasn't sure if you were looking for the install guide pics, or other pics in this thread.
Turbo kits!! djgab101 Forced Induction Forum 26 03-09-2015 03:24 PM
Turbo kit Brainstorming Gideon Forced Induction Forum 16 04-19-2009 12:54 AM
