Old 06-23-2018, 10:51 PM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Post Toyota Gear Ratio Interchangeability
Since I've had several Toyota transmissions apart now and was seeing a pattern, I took a bunch of measurements of the shafts and gears. Turns out all of the C-series gears are cross-compatible! Read more about it on my blog...
http://www.armstrongfamilyblog.com/a...nsaxle-options
ArmstrongRacing is offline   Reply With Quote
Old 06-25-2018, 10:28 PM   #2
atomic_hoji
Drives: 2018 Yaris SE 5MT
Who knew you could get a C-series dogbox?!? Assuming you have a spare $6k sitting around. lol
Interesting read, thanks Tom!
-- Adam
atomic_hoji is offline   Reply With Quote
Old 06-26-2018, 06:32 AM   #3
tmontague
tmontague's Avatar
Good to know!
Old 06-26-2018, 02:47 PM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I did a less detailed investigation several years back when I built my gearbox, but came to the same conclusion for the C5x gears. That's how you get the super overdrive 5th gear and closer 1-2, 2-3 ratios. =)
Old 06-29-2018, 08:07 AM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Awesome stuff!!
Old 06-29-2018, 11:30 PM   #6
ArmstrongRacing
Data doesn't lie
Yes that’s correct! If it wasn’t for you and Bluevitz tearing into these gearboxes before me, I wouldn’t have been so interested to do further research. So thank you!
Old 06-30-2018, 07:06 PM   #7
Bluevitz-rs
I was the one that built and documented the c160 conversation for the first Gen platform.
Old 06-30-2018, 09:14 PM   #8
Ronnie V
Drives: 04 3dr HB and 04 5dr RS
Is this documentation still around for the first gen? I want to do a 6 speed and a LSD this winter........
Ronnie V is offline   Reply With Quote
Old 07-01-2018, 12:21 AM   #9
3cyltrbo
I need this in my life!
someone teach me how.
I hate the huge bog between 1-2 and 2-3, but I love the relatively low hwy rpm in my 2010 CDN model Yaris.
teach me
3cyltrbo is offline   Reply With Quote
Old 07-01-2018, 05:02 AM   #10
Bluevitz-rs
Yup
http://www.yarisworld.com/forums/sho...eed+conversion
Old 07-03-2018, 01:37 PM   #11
CrankyOldMan
teach me
Watch Armstrong's YouTube videos on rebuilding a C60 gearbox. Same basic idea, just has the extra gear on one end. =)
Old 07-08-2018, 08:36 PM   #12
ArmstrongRacing
Data doesn't lie
OMG my bad dude. I corrected my post to give YOU credit.
Thank you for showing us the way with the 6-speed brother!
Old 07-08-2018, 08:40 PM   #13
ArmstrongRacing
Data doesn't lie
Thanks Sam! I have made it my purpose to put out a bunch of Toyota gearbox info in writing and video form. I hope to show everyone how to modify these gearboxes or possibly entrust me to build some for the community. So for Trevor and Taylor are the only people to receive gearboxes from me....let’s change that!
Old 10-06-2018, 04:22 PM   #14
swingtech
Drives: NCP131
Hi Guys ,
I am planning to use C150 gearbox 3rd 4th 5th gear set to C56 , are these gears same in size ? Can I use the C56 synchronizer and slider ?
Thanks in advance
swingtech is offline   Reply With Quote
Old 10-08-2018, 12:20 AM   #15
Runethecursed
Drives: 2009 Yaris S
Awesome work, its a shame the C trans wasnt used in conjunction with some of the bigger v6s and i4's
i think those where E coded tranS.
Runethecursed is offline   Reply With Quote
final drive, gear ratio, lsd, transmission
2015 Toyota Camry Kal-El Off-topic / Other Cars / Everything else Discussions 9 04-18-2014 06:47 PM
Gear fault on a 2009 manual toyota yaris please help! Gretch2689 UK 1 03-06-2014 01:41 PM
Close ratio gear kit Vanquisher Performance Modifications 8 09-01-2010 12:18 PM
