03-16-2019, 06:23 PM | #11 |
Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
Proposed Wiring for the F/IC
I used the engine control diagrams I got from TIS for the 2008 Scion xD. Also attached is a pic of the 2ZR Engine Control I found online and a link to the F/IC wiring diagram. Please chime in if you see anything amiss or have suggestions. I will add the diagrams for the power supply and ground for the F/IC later.
Interestingly, the tuner with whom I was speaking said that it would be unnecessary for the F/IC to control camshaft timing and that the stock ECU would control that. He seems very knowledgeable, but this just seemed odd to me. I suppose though if it is true and the F/IC is not controlling timing, that the crank would not need to be connected either. AEM F/IC Manual: https://www.jegs.com/InstallationIns...17-30-1913.pdf
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 03-19-2019 at 07:53 PM. |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
3rd gen 2zr swap with 6 speed | stidnam | Performance Modifications | 97 | 06-29-2021 04:59 AM |
Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-09-2012 11:35 PM |
ZPI Turbo for one lucky Yaris owner..... | ZPIracing | Forced Induction Forum | 27 | 04-26-2007 10:36 PM |
