02-24-2023, 08:17 AM | #37 |
Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
Which TB did you try to install? I'm not sure if the 2ZR TB would work. The one that is used was from a Toyota Matrix with 1ZZ engine, PN 22030-0D030.
02-25-2023, 04:16 PM | #38 | |
Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
Its some of the 1az/2az that don't work, tho some of them do. It just needs to have the correct case on the back unless you get lucky and your ecu doesnt throw a fit about having a different circuit board but my car did not like the new tb until I put the 1nz-fe chip on which could just be because I have a different ecu as NZDM rather than JDM import. |
02-26-2023, 01:41 AM | #39 | |
Drives: 2007 5dr canadian import Join Date: Dec 2016
next one i pull im drilling the rivits in the wrecker before i even leave |
02-26-2023, 02:41 AM | #40 |
03-01-2023, 05:54 AM | #41 |
Spent a couple days messing around with an intake pipe, my old man helped me braze it up, its brass and copper 57mm ID. Its a weird "S" shape and took a bit to get the angles right. It uses two normal intake boots large ends so that it fits on nice.
The upside down standard boot faces the oil breather backwards and puts a lot of pressure on the air box lid, this has fixed that . I need to make some vids of how she sounds because damn it sounds good now. Last edited by Compeer; 03-03-2023 at 11:37 AM. |
03-04-2023, 06:20 PM | #42 |
I have found a soloution to the problem with the rs manifold at the pickapart wreckers today I found a fielder with 1nzfe and the short intake AND an intake runner!
Ok so the runner is two part with a hollow passage for the exhaust gasses and has a port that runs to each intake. Effectively making this an intake heater! It was totally full if carbon, no way it was even working, so my plan is to make an egr blank off for my egr valve, It will be totally full of smut and not working anyway. Anyway I have JB welded the ports up, so now its just an intake runner. Will attempt to install this when the JB weld has fully set and then will look at the egr blank off and making an oil catch can so we can keep the intake nice (there was oil seeping out of the intake onto the engine from the breathers) Last edited by Compeer; 03-05-2023 at 11:32 AM. |
03-05-2023, 09:25 PM | #43 |
Ok I went and got the longer studs today, you will need the studs, the front oil breather pipe, the runner and gasket +JB weld and a hacksaw.
I used JB weld on the ports and cut the end off. Installed with the long standard manifold to try that! She is tight and now there is a process to take off the vvti solenoid which involces moving the intake manifold a bit. All buttoned up, I have clocked the hose to fit. The runner is 25MM and so with the long non-rs intake manifold she has 100mm of straight section before entering the head. I have just reset the ecu and let it idle till warm, she starts from cold at 2100rpm which drops to 1500rpm, then 720rpm when warm and then starts at 1200rpm when warm like a normal car. Car sounds so damn good sitting here idling, will be testing it later. Next steps are to get my 1zz-fe injectors serviced and installed, build a two in one oil catch can for both oil breather lines and then order a custom exhaust header. |
03-06-2023, 01:14 PM | #44 |
I thought the purpose of the RS intake was to have shorter runners, but now you're adding a spacer or two, wouldn't that be the same as stock length? Is there something else special about the RS intake manifold?
03-06-2023, 08:25 PM | #45 | |
Longer intake=lower powerband Shorter intake= higher power band So the RS manifold is a failed experiment until I can mod the heater pipe and see if it will fit on allowing for a 25MM shorter runner. With the Runner on I now have 100mm of straight intake and IDK I guess the tooter guy was on to something because it feels better to drive off the line. Lucky I get these things at the wreckers and I don't pay much for them, because I now have a spare ported manifold. |
03-07-2023, 10:38 PM | #46 |
Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
you wont get any gains, my last racecar build, i found out for NA, you are severly limited by the camshafts lift and duration.
03-08-2023, 03:37 AM | #47 | |
After I get a set of exhaust headers made I will look at a cam regrind from Franklin cams here in auckland, they like messing with toyotas and they have done them before as we use the 1nzfe as a jetboat engine here a lot. Last edited by Compeer; 03-08-2023 at 03:49 PM. |
03-08-2023, 07:10 PM | #48 |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
Excuse me? I wanna see this, that sounds awesome. The 1NZ-FE doesn't get the love it deserves in North America.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's |
03-13-2023, 01:44 PM | #49 |
03-20-2023, 04:04 AM | #50 |
I have use the RS intake manifold and not using any spacers
have to cut 1 bolt (knock sensor bolt I believe), and cut some coolant line and reroute the line |
03-20-2023, 01:37 PM | #51 | |
Nice so the bolt i didnt know I had to move and the hose I had realized was going to need modified, Right now im pretty happy with how the long set up is performing but will in the future try that, did you notice any difference? Last edited by Compeer; 03-20-2023 at 02:08 PM. |
03-21-2023, 03:00 AM | #52 | |
but on dyno, my peak torque shifts 300rpm higher with stock manifold, the torque drop 25% between peak torque and torque at rev limiter with RS manifold, the torque drop 19% between peak torque and torque and limiter |
03-21-2023, 12:54 PM | #53 |
id love to know how much lower the peak torque comes on with the RS egr plate and the STOCK non rs manifold
03-21-2023, 10:31 PM | #54 | |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
1ZZfe mod info | darkMINI | Performance Modifications | 21 | 07-12-2011 11:41 PM |
swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
