Old 04-11-2022, 04:45 PM   #73
RomanDave
Drives: 2NZ ITB NCP10
As anyone who's done trackdays etc knows, it can add an incredible amount of admin to try film things yourself.
Fixing camera angles, dealing with dead gopro batteries, full SD cards, suction cup mounts failling off, and so on.
It adds lot onto what can be quite a busy schedule already.
So I was incredibly stoked that there was enough interest for some guys to come spend a night filming my efforts at the drags.
Then going through all the motions of putting together a nice video from the footage.
If anyone's wanting an insight into the trials and tribulations of drag racing an echo, Have a geez.
It was a real fun night.
https://www.youtube.com/watch?v=uUlqZsjQanI
RomanDave is offline   Reply With Quote
Old 12-28-2022, 06:26 PM   #74
Compeer
Drives: NCP90 TRD Yaris Manual
Are you still racing the car? I know its a year on but keen to get along to race days in 2023 and it would be awesome to hook up with some other people modding and racing these little cars.
Working towards a supercharger set up for mine, slowly picking my way through base mods like suspension and things and would love to pick your brain as I move forward to ecu and what not.
Compeer is offline   Reply With Quote
Old 01-02-2023, 07:34 PM   #75
theinteriorautomechanic
Drives: Slowcart
Hi I just wanted to find out if the JUN cams are drop in cams for US Market 07-11 Yaris? I'm planning on doing BC Valve Springs as well as a bunch of other N/A mods. Are these drop in cams? Or will I need extensive tuning? Currently I am running an FTG Reflashed ECU with higher redline and adjusted A/F.
theinteriorautomechanic is offline   Reply With Quote
Old 01-06-2023, 01:26 AM   #76
remcafee
when i had 9 inch lift jun cams thry ran a little weird at idle, triggering random misfires every once in a while, i solved that issue with 1 step colder plugs and it ran great on stock map
Old 04-17-2023, 08:45 AM   #77
saikouguy
Drives: Toyota Echo
Unfortunately Dave has moved on from this setup. You can read his build here: https://oldschool.co.nz/index.php?/t...5-toyota-echo/
Or alternatively join the Facebook groups and ask him there:
- https://www.facebook.com/groups/NCPClubAustralia
- https://www.facebook.com/groups/473202130211974
saikouguy is offline   Reply With Quote
prius c 1nz swap Zedicus Performance Modifications 29 06-01-2023 03:35 PM
Prius Piston swap in 1NZ (update pls) rabbito Performance Modifications 2 06-12-2016 10:18 PM
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Toyota says don't call them Priuses -- call 'em the Prii Kal-El Off-topic / Other Cars / Everything else Discussions 7 02-22-2011 10:30 AM
