#73 | |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
The Tein's lowering springs are progressive and the 1.9in drop makes a huge difference. I remember before I installed the lowering springs, I had a lot of body roll. Now I feel like on rails. Before I got the Bilstein B8 struts, I thought about getting the Tein's Flex Z, but now, I'm content with my suspension. I think I'd just add rear sway bar, get B8 shocks for the rear, and maybe front tower bar. |
#74 |
cant lower.....roads wont allow it ..chins allready take hits as it is and im not talkin about just driveways but actual dips in the back roads
#75 |
![]() ![]() ![]() Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
I am back using the TRS sportivo suspension currently, thats pretty close to stock height and rides nice, the springs could work good for you and are still around, little stiffer and tiny bit lower? I guess tho you have snow to deal with.
#76 | |
its the roads i go burn up that are the issue....the super fun twistys have alot of odd dips n such, but were talkin twisty mountain roads that run like a rollercoaster...so youll hit hard dips and the chins will scrape....im at stock hight ..stiffer springs would help a little..so a tiny drop with some stiff would be fine |
#77 | |
Tags |
brakes, ncp90, trd yaris, upgrade, vitz rs |
Thread Tools | |
Display Modes | |
5 Lug Conversion | DarkShadowFox | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 60 | 05-18-2018 02:33 PM |
Rear SE axle beam swap | yariseggvvti | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 25 | 09-24-2017 11:26 PM |
60/40 split rear seat swap question | jayeh | Cosmetic Modifications (Exterior/Interior) | 12 | 10-28-2012 03:07 AM |
When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 07:03 AM |
Catback exhausts and rear disc brake conversions | eTiMaGo | Performance Modifications | 59 | 01-04-2009 06:13 PM |
