08-15-2023, 12:20 PM | #1 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Rising rate fpr
Has anyone tried this on a Yaris yet? Thinking about a 2:1 rising rate FPR that only sees boost so the base pressure can still be matched to stock.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
08-27-2023, 08:18 PM | #2 |
Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
I haven't but it does sound interesting.
09-18-2023, 12:35 AM | #3 |
Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
You can't use rising rate FPR on a yaris because of the returnless fuel system. You must do a full custom setup or modify the fuel sending unit
09-18-2023, 09:04 PM | #4 | |
Obsessed with 1.5L
Thats the point would be to do all that
09-25-2023, 03:59 PM | #5 |
GRIDLIFE Sundae Cup Yaris
Drives: 06 CDN Yaris Base Join Date: Apr 2017
A 2:1 is not going to get you very far. It is far more effective to just make it a standard return system with a 1:1 FPR to just account for boost pressure then make fuel adjustments with your ECU. I am running a speeduino on E85 with the stock fuel system and pump. It runs out of steam and starts losing pressure around 5 psi of boost. I basically just open the injectors all the way and let it eat lol. Retunless is a bitch with forced induction! If you are dead set on a FPU, you need a much higher raising rate to account the the increased air volume, usually a 10:1 or 20:1 FPU is common, or was common 20 years ago. But, then you have no way of pulling timing with boost and you will reach the limit of the stock MAF sensor very fast. If you are going to put in the work to make it a return system, just go standalone and a 1:1 FPR.
09-25-2023, 07:07 PM | #6 |
Did you do google searches with the keywords "upgrade, modify, add, returnless, fuel system, fpr, regulator"?
Google works still and one of the first videos is gold https://www.youtube.com/watch?v=yl7a9GWADVs https://www.youtube.com/watch?v=I4F2UXGr67g https://www.autospeed.com/cms/a_113087/article https://www.autospeed.com/cms/a_113088/article.html |
03-06-2024, 08:27 PM | #7 |
What are the key challenges and considerations involved in modifying the Yaris' fuel system to accommodate a 2:1 rising rate FPR, especially given the returnless fuel system, and how have others addressed similar issues in their setups?
03-29-2024, 09:25 PM | #8 |
Admin delete previous posting. Bot and links to a dating site.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
BLITZ supercharger kits IN STOCK | cali yaris | Micro Image | 34 | 06-02-2012 10:31 AM |
