Old 09-18-2015, 11:58 PM   #145
xdarkxfirex
Drives: 2015 yaris le
What about the automatic? I get a squeaking sound shifting into d or taking off most times
xdarkxfirex is offline   Reply With Quote
Old 09-19-2015, 09:33 AM   #146
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
could be a bad motor mount
Old 11-18-2015, 04:59 PM   #147
esse10
Drives: 2009 yaris 2 door
squeak
Anybody figure out how to lube the inside of the Clutch release fork boot pivot point? blue arrow in this picture.
File Type: png toyota-yaris-clutch-parts-components.png (36.9 KB, 278 views)
Old 11-18-2015, 05:02 PM   #148
tmontague
tmontague's Avatar
I just stuck a straw in there from a can of lithium grease and sprayed. I also sprayed it on all the shift linkages on top of the transmission. My squeak went away and has been for a couple months now.
FWIW I had a squeak when i'd depress the clutch pedal
Old 11-18-2015, 06:23 PM   #149
esse10
ok
oh okay, I was skeptical about doing that cause you don't want to spray the clutch disc or something that'll cause more harm or start slipping. I was thinking if maybe I can get a camera probe in there to see what specific parts to lube or not.
Old 11-18-2015, 07:32 PM   #150
tmontague
tmontague's Avatar
I just made sure I didn't direct the straw directly in the direction of the clutch. Haven't had any issues since.
When I swap out my flywheel and clutch this summer i'll be adding a lot of grease to that area to ensure no sqeaking happens again.
Old 02-15-2016, 01:13 AM   #151
RiceCake
Drives: 2007 Steel blue yaris sedan
This is a definite fix!!! I've been looking everywhere for an answer and am so glad I stumbled upon this forum. So many useful guides!! Thank you again for the fix!
RiceCake is offline   Reply With Quote
Old 10-11-2016, 12:12 AM   #152
yarisgc
Drives: Yaris NCP91R 1.5 Man 5d Hatch
I had this little annoyance too (little squeak noise moving gears)
A couple of sprays of RP7 solved this for me, 2 1 second sprays once, leave 5 mins, then repeat with a 1 second spray on the area in the original posters pic, (thanks).
Yay! My first post, Hi people nice to meet ya :)
yarisgc is offline   Reply With Quote
Old 08-10-2017, 12:07 PM   #153
Kawiman
Drives: 2010 hatch
Wow!
I've got that ,too.
I can't believe it's so common.
I haven't gotten around to addressing it because i didn't know it could be so easily reached.
Thanks!!
Kawiman is offline   Reply With Quote
Old 09-18-2017, 01:54 AM   #154
komichal
Is this engine-dependent?
My Yaris 2007 uses 2SZ-FE engine and I am not able to find this part in the engine compartment...
Old 10-08-2017, 05:15 PM   #155
Kawiman
Drives: 2010 hatch
Thanks!
I used some product called Zep S 2000
It's clingier/stickier than WD40. And shouldn't just wash off.
The squeak is gone.
since I only heard it shifting into 2nd gear, I was affraid it was coming from the tranny.
Old 07-07-2021, 08:56 AM   #156
07Yaris94
Drives: Yaris SR 2007
Guys, I'm convinced this is my issue, but I cannot for the life of me find this part. I have an 07 Yaris (UK). Can someone show me where I'll find this in my engine bay?
Originally Posted by kou View Post
lube this part. if you look under the hood at your linkage move this part side to side and lube. white lithium grease in the spray can works great.
07Yaris94 is offline   Reply With Quote
Old 07-13-2022, 07:59 AM   #157
esse10
squeak noise no more
I just recently replaced my Clutch/pressure plate/throw-bearing ........and in fact i replaced the whole transmission gear box in my car. The squeak is coming from the fork pivot point and also the throw-bearing when it pushes the fingers of the pressure plate. Just put a little coating of grease on those parts and ........problem solved- NO MORE SQUEAK.
Old 03-18-2024, 07:16 AM   #158
Moons
Drives: Man
Send a message via ICQ to Moons Send a message via AIM to Moons Send a message via Yahoo to Moons
Night dating, no obligations, one night only
Freedom of meetings, no obligations
Verified Ladies
Moons is offline   Reply With Quote
Old 03-18-2024, 07:44 AM   #159
Bluevitz-rs
Verified Ladies
Finally! Some relevant information on this thread.
But sadly, you forgot to include the smile so I’ll need to report you
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
2009 Yaris "S" - no 5MT Hatchback? Latka New YARIS Purchase Forum 21 11-07-2008 04:16 PM
New transmission at 8.5K miles! d2dailly DIY / Maintenance / Service 17 09-22-2007 11:41 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 03:51 PM
