Old 02-26-2007, 07:21 AM   #91
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Sylvania SilverStar 7507AST - Signal Light Bulbs
Old 02-26-2007, 12:27 PM   #92
St_G
Drives: Black 2007 Yaris Liftback 1.5
Huh? Did you read the thread? I ordered them and within about a week I received the wrong bulbs, emailed the guy, got a quick reply on what I (and others in the same situation) should do to get the right bulbs...and then the guy went to ground and stopped replying to emails. And never sent the replacement bulbs. All together, it's been about 6 weeks, I guess.
Originally Posted by Go4th View Post
when did you order it? let it take 3-4 weeks..
St_G is offline   Reply With Quote
Old 03-10-2007, 06:21 PM   #93
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Chris,
Did you ever swap out the rear turn signal bulbs for these? Did it eliminate the orange in the rear or is that in the housing? Also have you changed out your reverse bulbs for something a bit brighter if so what did you use in those? Thanks.
SPONSORED BY
Old 03-10-2007, 06:31 PM   #94
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
LOL, seems like im 5 minutes behind each of your posts tonight..
Anyway, yes. The front signal bulbs can/will work in the rear. The rear bulbs are orange, the lens is clear.. so yea, same as the front.
Old 03-10-2007, 07:07 PM   #95
brickhardmeat
Lonesome Cowboy
Thumbs up
Yeah I'm on a rampage. Well I might just have to get another pair. Won't be as dramatice as the front the way the housing is. I ordered the turns from xenonmods and had -0- issues, got the order fairly quickly.
SPONSORED BY
Old 03-11-2007, 09:45 PM   #96
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
i said this in another post but i just used 1156 clears in the fron/rear of the turn signal bulbs.all it took was a slight twist and it went in with no problem.
http://www.carid.com/toyota-accessories/
site has a FEW interesting yaris items.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 03-20-2007, 08:34 PM   #97
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Just got back from a month in Europe, and found another package from xenonmods.com waiting for me, with the correct bulb sizes. Yay! Good for Rich and crew.
St. G... you get yours yet?
2006 Red Blitzed RS 5-door
Old 03-21-2007, 05:42 PM   #98
Astroman
Modded Moderator
Astroman's Avatar
I just now ordered mine. Figured it would look sharp on my Meteorite Metallic LB.
Old 05-24-2007, 08:16 PM   #99
TheCutsman
TheCutsman's Avatar
Drives: 07 Meteorite 3 Dr Liftback
Awesome, definitely alot cleaner looking. Put mine in yesterday, I ordered off the ebay sale and my order was correct.
______________
07 Meteorite Metallic Liftback
TRD Lowering Springs
Tanabe Strut Tower Bar
Fujita F5 CAI
Autometer Tach
NST Quickshifter
TheCutsman is offline   Reply With Quote
Old 07-05-2007, 10:40 PM   #100
Sway84
Sway84's Avatar
Drives: 07 Yaris HB
Send a message via MSN to Sway84
whats the diffy from these ones from xenonmods to the autolumination?...
Rice on, Rice Off
Ron Cabading
Sway84 is offline   Reply With Quote
Old 07-06-2007, 01:03 AM   #101
Black Yaris
der Zeck
Black Yaris's Avatar
what is the actual bulb # 7507A?... or 1156A? I am going to swap out for some silverstars tomorrow
Old 07-06-2007, 06:07 AM   #102
njyaris
YARIS NEWBIE
njyaris's Avatar
Drives: YARIS 07 LIFTBACK
Send a message via AIM to njyaris Send a message via Yahoo to njyaris
kewl 12.99 not bad at all
Hudson County, New Jersey
njyaris is offline   Reply With Quote
Old 07-06-2007, 10:04 AM   #103
brickhardmeat
Lonesome Cowboy
bulb # 7507A is what I used and it fits the front and rear turns, the guy above crammed an 1156 which is the back up bulb into a turn signal from what I gather and says it works, the pins are offset differently if I remember correctly
7507 is the correct size for turn signal bulbs in the hatch
SPONSORED BY
Old 07-06-2007, 10:50 AM   #104
atarisolid
AtariSolid
atarisolid's Avatar
Drives: Flint Mica Yaris
I have an 07 sedan s, i noticed that the headlights on mine look different than the ones on the 3DR on the first page of the forum. will these lights still work. and if i were to get them, do i take the amber reflector out of the headlight to install them?
atarisolid is offline   Reply With Quote
Old 07-06-2007, 10:52 AM   #105
brickhardmeat
Lonesome Cowboy
I am not sure that your's are the same.
catch vodka
SPONSORED BY
Old 07-12-2007, 01:00 AM   #106
Flint_Yaris
Flint_Yaris's Avatar
Drives: 07 Yaris S. Flint Mica.
Just ordered them for my sedan.
Flint_Yaris is offline   Reply With Quote
Old 07-12-2007, 02:34 AM   #107
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
Originally Posted by ASHRAF View Post
I've ordered the bulbs but they sent me wrong ones
just two too tiny bulbs
any idea where can they be used???
I will order the bulbs next few days
thanx for the easy, cheap, & perfect mod.
maybe you can use them in the side marker lights. it's not easy to install them, but it will give you the same effect, getting rid of the orangey color in the side marker housings and still blink orange.
reznunt is offline   Reply With Quote
