AKA Samurai Racer
diy for steering wheel change
has anybody changed a steering wheel on a yaris yet? if so , i wanna put on a momo , but im looking for a DIY? any help would be greatly appreciated!
What about the airbag?
![]() ![]() Drives: 2007 Yaris Hatch Join Date: Jul 2007
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
You two are aware that all you have to do to disable the airbag is disconnect the negative battery cable, right?
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
I think etimago has a momo.
SPONSORED BY ![]() |
you will have to disconnect the battery. remove the airbag and the steering wheel. you'll need an adapter of some sort to install the aftermarket steering wheel.
thats it pretty much. and i'll rather not have an airbag on my car. i have seen what they can do and i'll take my chances with the seatbelt on. planing on removing my stock wheel and going with a momo also, great quality. |
#7 | |
Passin' The Gas...Station
And when the car dies 'cause the battery is not hooked up there is not much of a chance of a frontal collision while parked on the side of the road. I thought there was a "loop" that controlled the ignition/operation of the car. When the bag does deploy, the car will not operate. The bag sensor has to complete this electrical "loop" to tell the car it's ok to operate. I'm thinking someone who is better versed in this will step forward. The aftermarket kit must have an "override" part/device that will continue this "loop". I'll wait for the expert, should be here at anytime....always is. Chuck
![]() ![]() Chuck |
![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
and you will get the airbag warning light, without it...
also good luck, if you happen to get in an accident and the airbag is missing, not much luck suing for face repairs. |
lol i have to agree with not having an air bag. i hate to say it but most times your face is hurt more with the bag than without. that bag deploys in milliseconds and ive seen a few friends including myself get facial burns due to it. just wear your seatbelt thats all. so whatever not to get off topic... they sell adapters that keep the srs drivers airbag circuit shorted (simulates there being an airbag present) just search sites that carry hubs and steering wheels, easy to find. and its pretty difficult to blow-up an airbag installing a st.wheel. unless your applying voltage to it, which if you are your insane.
![]() 1.disconnect the neg. battery cable and wait for 2min. straighten wheel so it is at 12 o'clock 2. unplug the srs connector at the bottom of the steering wheel. it is yellow 3. there should be 2 torx bolts one on each side of airbag, remove them. 4. pull off airbag. 5. remove wires for horn . 6. mark steering shaft and hub for alignment for later when putting in new wheel. remove steering hub bolt, usually 17 or 19mm 7. use a pull hammer to remove wheel, but if not available with 2 hands pull wheel towards yourself, might have to rock back and forth a little . it might be tough, so be carefull not to smack yourself in the face with it when it pops off ![]()
![]() 07 Yaris LB 5spd AE86 Corolla GTS 5spd http://microimage.ning.com/ http://www.microimageonline.com/store.html |
I wonder what your insurance company will think if they become aware that you have disabled or worse removed the airbag. And, will they cover you in case of an accident.
Somehow, I think you could be in for a mess of trouble. Sorry, but what's up with some of you guys... wanting to disable DRL's and airbags?! |
#12 | |
Lonesome Cowboy
![]() ![]() Airbags are for sissies. ![]() ![]()
Actually, I don't think there is any insurance discount for the driver's side airbag. Front airbags are required standard equipment in all later model cars and are assumed present and fully functional by insurance companies.
Try telling your insurance company you have removed the steering wheel airbag and installed an aftermarket steering wheel. Good luck! |
I think I'd take the burn....1st degree, hell I get that trying to pull my fishsticks out of the oven. Unless you can tell me you're an emergency responder, I'll believe what I think is a good idea.
I'm in no means discouraging the mod. Sounds pretty unique. I thought the steering wheel mod went out with the popularity of the airbag. Everyone does what they feel they want to or need to. I just don't see where there is a pro/con debate for airbags. I think one time you do not want the airbag to go off is if you are smoking a pipe. ![]() Chuck
![]() ![]() Chuck |
Mr Attitude
Drives: Blazing Blue 5 Spd Join Date: Jun 2007
My girlfriend is a Paramedic. After hearing her opinion on airbags just now, I'll never remove mine. She says she's seen light burns, but mostly on the inner arms of the arm holding the steering wheel. Being that she never talks about what she sees at work, I was shocked in how she reacted when I told her people think airbags are more dangerous than not having one. She summed it up with my type of statement, look at it like population control. Only the stupid people will be harmed...
Has anyone actually LOOKED at their Yaris, especially the LB? There is only inches of car in front of the driver...I'll take my chances with my 6 airbags or whatever the LB has... Aftermarket wheels look great, but they belong on the track or at the show, that's my opinion.
It's scary to think that half the people surrounding you are below average... ![]() |
Another option is a TRD steering wheel with airbag, I think it was stock from the Supra, looks pretty good.
I indeed have a Momo steering wheel, and indeed the airbag warning light stays on at all times. But I do wear my seatbelt at all times (I'm kinda anal about that)...
Lonesome Cowboy
yeah, I snap mine in as soon as I get in the car
you know there was a time when there was no such thing as an air bag. the one in my vw malfuctioned and the light stayed on, the shop told me it would not deploy in that state and they wanted to maintenance it, I drove like that for 3 years, traded it in like that I guess I'm an idiot too.
heh... some people go skydiving, some dive with man-eating sharks, our extreme sport is driving without airbags
Yarisworld.com DIY Manual v3 | vodkalush | DIY / Maintenance / Service | 100 | 12-13-2022 05:55 AM |
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal | hasher22 | DIY / Maintenance / Service | 88 | 03-06-2014 06:40 AM |
Yaris wheel rate ratio (06+) ? | dsc_pat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 07-05-2007 05:43 PM |
DIY Oil Change | Bassmonkey | DIY / Maintenance / Service | 42 | 02-19-2007 08:37 PM |
Yarisworld.com DIY Manual v3 | vodkalush | Downloads for Registered Members | 30 | 01-21-2007 10:54 PM |
