Old 08-25-2007, 01:39 PM   #1
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
The Coilover Thread
I thought it might be good to make a definitive thread for Yaris coilovers. This would include what's available and any input people have. Please add to the list if you know of any other available applications.
Here's what's Available:
D2 RS Coilovers
Height adjustable
36-way dampening adjustable
Spring rates: Custom
http://www.d2racing.com
H&R Street-Performance
Height adjustable
Preset dampening
Spring rates: ?????
http://www.hrsprings.com
KW V3 coilover kit
Height-adjustable
14-way dampening adjustable (compression)
Infantile adjustable rebound
Spring rates: ?????
http://www.kw-suspension.com
Tein Basics
Height-adjustable
Preset dampening
Spring rates (F/R, lbs./In.): 224/174
http://www.tein.com
Tein Super Compacts
Height-adjustable
16-way dampening
Spring Rates (F/R, lbs. ??/??)
http://www.tein.co.jp
Megan Racing
Height-adjustable
32-way dampening adjustable
Optional Pillowball mounts (requires some modification)
Spring rates (F/R, lbs./In.): 280/336
http://www.meganracing.com
K-Sport
Height-adjustable
Front pillowball mounts
Compression/rebound adjustable
Spring rates (F/R, lbs./In.): 392/140
http://www.ksportusa.com
Cusco Compact-S
Height-adjustable
Preset dampening
Upper pillow ball mounts
Spring rates (F/R, kgs./mm.): 7/3.3
http://www.cuscoracing.com
Cusco Zero-1
Height-adjustable
Pre-set dampning
Spring rates (F/R, lbs./In.):392/18x (?)
eBay generic coilover sleeves
Height adjustable, no shocks
http://www.ebay.com
SilkRoad RMA8
Height-adjustable
8 Step Dampening
Spring rates (F/R, kgs/mm): 7/4
http://www.silkroad-usa.com/
HKS S-Compact
Height-adjustable
30-way adjustable
Pillowball fronts
Spring rates (F/R, lbs./In.): 280/448
http://www.hks-usa.com or www.hks-power.co.jp
C-One Sports Suspension Kit
Non-height adjustable (spring/shock kit)
Adjustable dampening
Spring rates (F/R, kgs/mm): 3.8/2.6
http://www.c-one.co.jp
Old 08-25-2007, 02:17 PM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
D2 Racing RS Coilovers
D2 Racing Coilovers Feature:
Fully adjustable (36-way dampening(51mm shocks), and ride height)
Custom spring rates (3.5, 5, 7, 9, 11, 13, 15, 18, and 22 kg/mm)
Pillow ball mounts included w/ camber plates!
Telflon-coated threads
Flawless CNC finish
2 Keys for adjusting ride height
Carefully matched spring and damper rates
1 year warranty
http://www.nolimitmotorsport.com/prod/D2-T024
SPONSORED BY
Old 08-25-2007, 03:50 PM   #3
kurokoma-kun
Drives: 2007 Yaris HB
Thanks so much you guys! I've been trying to gather this info on my own...
my yaris, kurokoma-kun
Old 08-25-2007, 05:28 PM   #4
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
on www.bulletproofautomotive.com you can see that the cusco compact s coilovers are 7k in the front and about 3k in the rear.
Old 08-25-2007, 05:41 PM   #5
Thirty-Nine
Noted -- thanks!
Also, is there a way we could possibly get this thread as a "sticky?"
Old 08-25-2007, 05:46 PM   #6
tca4
tca4's Avatar
Drives: Yaris RS (white)
How about tein super wagon?
tca4 is offline   Reply With Quote
Old 08-25-2007, 08:42 PM   #7
03Z33
03Z33's Avatar
Drives: TCR10
Silkroad standard rates are 7K front and 4K rear. I special ordered mine with 8K front and 5K rear, they are great
It may also be nice to mention which coilovers also include adjustable sway bar links and offer separate height adjustment from the spring adjustment. Silkroad and HKS both offer this as I'm sure a few of the others do.
Old 08-25-2007, 08:46 PM   #8
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
good idea! can we add min/max height specs?
reznunt is offline   Reply With Quote
Old 08-25-2007, 08:48 PM   #9
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
oooo... how much for the silkroads?
barebonedvitz is offline   Reply With Quote
Old 08-26-2007, 02:23 AM   #10
blueskana
blueskana's Avatar
Drives: 2007 Yaris LB
Great info, thanks!
blueskana is offline   Reply With Quote
Old 08-26-2007, 03:16 AM   #11
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
I guess that would be more accurately refered to as bump adjustment.
Old 08-26-2007, 06:04 AM   #12
jdium
Mr Attitude
jdium's Avatar
Drives: Blazing Blue 5 Spd
General prices, maybe posted with an * asterisk would be a worthy addition?
It's scary to think that half the people surrounding you are below average...
jdium is offline   Reply With Quote
Old 08-26-2007, 08:12 AM   #13
I think you mean Super Compacts, they're not sold in the US, but according to TEIN.co.jp they come with the same springs as the Basics, but offer damping adjustment and EDFC compatibility.
Old 08-27-2007, 11:30 PM   #14
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
I have the Megans. They don't have the pillowball. You have to buy them separately and modify the install on the car. I now have them setup at the hardest setting and think I might actually change the springs in the front to a stiffer spring rate. I may also look into the camber bolts to adjust the camber instead of the pillowballs.
My friend had the Tein Basics which were too soft if you wanted that tucked in look.
He changed them up to another set which is way more stiffer. At their softest setting they are the same stiffness as my Megans at the mid setting. Sorry I can't remember what they were. I'll try to find out.
Sponsors and Organizations:
Toyota Rally Canada
Yokohama Tire Canada
Western Canada Rally Association
Ecurie (Team) Snoopy Canada, racing since 1966
mojoyaris is offline   Reply With Quote
Old 08-27-2007, 11:43 PM   #15
brickhardmeat
Lonesome Cowboy
softness has nothing to do with tuck
you can get the wheels tucked in depending on size and offset with the teins as well
the Megans and others will go lower but the Teins don't throw the geometry of the car off...
...and they are a very nice ride for street
how are your soft tissue injuries?
SPONSORED BY
Old 08-27-2007, 11:53 PM   #16
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
I'm not talking about street. Track usage the Teins are too soft.
For the front if you want to tuck in your front wheels, it doesn't matter the offset really. What it is, is the plastic liner that you have to remove which gets in the way of the suspension movement. When you are cornering hard the wheel comes up and rubs against the liner.
For me I have about a half inch gap from the tire to the wheel well.
I guess you already have a set of Tein Basics?
(I'm a nice guy. be nice.).
Toyota Rally Canada
Old 08-27-2007, 11:55 PM   #17
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
question. if you track your car and remove the wheel well liner and then drive it daily w/out the liner would a lot of debris get into the car? sorry if it sounds stupid but i rarely look at that area of the car
Old 08-28-2007, 12:00 AM   #18
Black Yaris
der Zeck
Black Yaris's Avatar
so far, will all agree the softest springs are the Tein's? so they would probibly be the best for a daily driver, who just want to ride low?
OFFICIAL Yaris SEDAN thread SimmZ Photo-Video-Media Gallery 1705 01-13-2020 11:20 AM
Shift lever thread size Chaad32 Cosmetic Modifications (Exterior/Interior) 16 01-30-2015 02:16 PM
Shift Knob Thread Patter? eight_heads General Yaris / Vitz Discussion 6 10-21-2009 10:25 AM
Post Whores-aka Yaris chat thread Black Yaris Off-topic / Other Cars / Everything else Discussions 21 07-12-2007 05:37 PM
Thread request - Yaris is new in the US makaluch Cosmetic Modifications (Exterior/Interior) 1 08-13-2006 12:16 AM
