Old 07-28-2006, 08:17 PM   #1
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
TANABE DF210 Spring Install [pics]
*NOTE TO INSTALLERS*
This is just a GUIDE for the general way of doing the install. This is NOT a bible, you may find an easier way and much quicker way to do the entire procedure. Please add your notes and findings if it will be helpful to others.
Do NOT F*CKING BITCH if you dont know right from left, loose from tight!
Enjoy.
Just finished the install today.
Special thanks to C2AUTOSPL! for hooking me up!! After you see how easy this was, go ahead an order up a set from Jay.
Total time, with finding correct sizes, removing tires, jacking up, positioning jack stands, etc., was just under 2 hours, including cleanup, and taking these pictures and notes.
Your times may vary.
Before doing any spring installs, I like to measure each corner, to compare later the drop given. I was at 15" at all four corners. This is always the way I measure... bottom of wheel well, in the center to center of wheel
AFTER measurements were 13" all around!
Starting off with the easiest part first, the REAR Springs.
We will be doing both sides at the same time..
Break the lug nuts loose, then jack up the car. Position jack stands, and remove wheels.
Tools Needed for rear:
9/16 deep socket; 1/2 drive
9/16 box wrench
Remove the lower shock nut & bolt. Remember to do both sides before continuing. This will give the most "play" in the suspension, to drop the springs out.
Once both lower shocks bolts are out, you can press down on the rear axle's, and the spring will just fall out.
Comparing the Tanbe DF210's to the Stock Toyota.
Be sure to re-install the top rubber coil dampener, so that the spring sits in the pocket. NOTE make sure the Tanbe DF210 logo is right-side-up!!
Tanbe sends this plastic cover for the bottom of the last 4 coils. I was told its to prevent any kind of chatter, being that area is compressed so close, that the coils may rub a little. PITA to wrap it all around, but it's for the best.
Rear Tanbe's installed. Tighten shock bolts, install wheels, and torque lugs to 75 Foot Pounds. Rear Complete!
Moving on to the fronts. I did one side at a time up here.
Tools Needed for Front:
9/16 socket; 1/2 drive
19mm deep socket; 1/2 drive
17mm box wrench
6mm allen key
Hacksaw
We need to remove the (2) Sway Bar end links, (2) Strut bolts, and (1) Brake bolt.
Follow the bolts with sizes marked, and remove.. any order is fine.
Should say LOOSEN and tighten below..
Once all is removed, the only thing holding the strut/spring assy., is the upper nut.
Open the hood. Remove the entire windshield wiper plastic cowl. Stay with me, its easier then it looks!
First, the wipers need to come off. Remove the cap, and with a 9/16 box wrench, remove the nuts.
Next, bend wiper arm, and rock it back and forth, while pulling straight up to remove it from cowl. NOTE, I marked the wiper and threads, to make sure I re-installed it back later in the same place.
Remove these (3) plastic push pins. And just set pieces out of the way.
[IMG]PICTURE MISSING![/IMG]
Next, pry up the rubber dust cap.
Under the cap is a nut holding the top of the strut assy., to the shock tower of car. Get your 17mm box wrench and loosen the nut while HOLDING the center from spinning, with a 6mm allen key.
Once loose, remove enitre assy., from car.
Again, not needed, but I marked some reference points.
Loosen the top hats nut a LITTLE with your 17mm and 6mm from before.
Get the strut assy., in a spring compressor.
Compress spring, and now you can SAFELY remove top hat, followed by the dust boot.
Comparing the Tanbe and Toyota springs.
Bump stop time.. You will need to shorten your bump stops, so that your not "riding the shocks" from your decrease in height.
Cut against the plastic center ring, to make a nice straight cut with a hacksaw.
**** NOTE ****
Follow your spring makers instructions, and search or call to find out how much if any needs to be cut if installing springs/struts OTHER then what is shown in this DIY.
Top hat and new, shortened bump stop.
Time to re-install the strut with the new Tanbe Spring, being sure to have the bottom of spring, inside the struts stamped groove.
Spring compressor not needed to install new spring. Tighten the top hat all the way (you can compress the spring assy., to see where it bottoms out).
New strut ready to install.... Reverse earlier steps,....... and installed!
I'm loving the new stance!
Enjoy the How-Do, I hope it helps!!
Chris07LB is offline
Old 07-28-2006, 08:37 PM   #2
Sp33dY
www.OZTOYOTA.com
Drives: Toyota Echo
Look forward to after pics . !!!
Meaured the distance from teh guard to the center of the wheel yet? :)
One question though .... Surely chopping a 3/5 of the bump stop off isnt the best thing to do??? Ive done this once on a mates Lancer teamed with Hotbits coilovers, purely to get another 1" drop. The ride however was a lot worse with the shortened bump stop, and shocks ended up squeeking badly after a few months.
So in effect, u chopped the bump stop instead of buying shorter shocks to stop the shox from riding ... right? Any idea if there are aftermarket shortened bumpstops ? Is the ride bouncy at all?
Would u consider replacing the bumpstop with a factory item and just buying shorter shocks for better ride quality?
www.oztoyota.com - Australian Toyota ECHO and YARIS Club
Sp33dY is offline
Old 07-28-2006, 08:45 PM   #3
Chris07LB
Chris07LB's Avatar
Very tired right now, but ill answer what i can...
1. The new measurement number is posted.
2. You NEED to cut the bump stops if using the stock shocks.
3. Tanbe USA, who I spoke with today, said the DF210's were designed to work with the stock shocks, and stock sway bar links.
4. When these shocks wear out, I will replace with Koni's.
Thanks for your concerns...
Old 07-28-2006, 09:24 PM   #4
spacemanoeuvres
spase peepole
spacemanoeuvres's Avatar
Drives: BLAZING BLUE Liftback 5 Speed
you rock, can't wait for the after pics!
we am spase peepole
spacemanoeuvres is offline
Old 07-28-2006, 09:41 PM   #5
Yaris_PR
Yaris_PR's Avatar
Drives: Red Yaris Hatchback on 18's
Send a message via MSN to Yaris_PR
Great work and post Chris... I can't wait to see those pictures.
Yaris_PR is offline
Old 07-28-2006, 10:27 PM   #6
C2AUTOSPL
Drives: 240sx, 00 Celica
NIce write up. This needs to be stickied. BTW, i got your lower bar here, just need to get the right box for it.
SUPPORT YARISWORLD'S VERY FIRST SPONSOR!!
C2 AUTOMOTIVE SPECIAL
24711 Redlands Blvd., Ste. I
Loma Linda, CA 92354
T: 909-796-8189
E-mail: info@c2auto.com
AIM: wide180sx
C2AUTOSPL is offline
Old 07-29-2006, 12:00 AM   #7
ChinoCharles
Drives: LB
WERE NOT WORTHY WERE NOT WORTHY
ChinoCharles is offline
Old 07-29-2006, 12:04 AM   #8
Yaris_PR
Yaris_PR's Avatar
By the way C2AUTOSPL , need to clear your PM's, I need to ask you a question about some parts...
Yaris_PR is offline
Old 07-29-2006, 12:06 AM   #9
C2AUTOSPL
sorry....PM box cleaned.
BTW, both DF210 and NF210 now instock.
T: 909-796-8189
AIM: wide180sx
Old 07-29-2006, 12:12 AM   #10
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
Drives: 5-Speed Liftback
Send a message via AIM to Ran Kizama Send a message via MSN to Ran Kizama
Nice write-up. I was installing mine earlier and the backs were a breeze. However, when doing the front I didn't need the allen wrench on the sway bar link and I also only undid the top bolt then swung it out of the way. Oh yeah, one more thing...
WEAR GLOVES
When attempting to undo the top of the front strut, I couldn't get a good feel with my gloves on. So I took them off. Upon applying pressure to my wrench, my hand slipped off and slid cleanly across that sharp aluminum cover that runs across the top of the engine bay. Blood across my engine cover and exposed bone has postponed my front spring installation until further notice.
Just a fair warning to others out there.
<- Idiot
Ran Kizama is offline
Old 07-29-2006, 07:09 AM   #11
Chris07LB
Chris07LB's Avatar
WEAR GLOVES
<- Idiot
Wish I was closer, Id button the front up over a beer or two for ya.
Feel better bro!
Old 07-29-2006, 10:20 AM   #12
Boo
Boo's Avatar
Drives: PW Yaris LB AT
Just wonder.. do you need to use spring compressing tool for putting back the rear spring?
Boo is offline
Old 07-29-2006, 01:00 PM   #13
Chris07LB
Chris07LB's Avatar
Follow the DIY above, there was no mention or need for a spring compressor in the rear.. there is no strut, of shock thru the center.. Its a completely different ballgame back there.
Old 07-29-2006, 02:18 PM   #14
Chris07LB
Chris07LB's Avatar
Thanks Jay.. I look foward to getting it!!!
Old 07-29-2006, 02:19 PM   #15
Chris07LB
Chris07LB's Avatar
Is everyone able to see all the pictures above in the How-To?? Just want to be sure knowone's getting an error mesasage of sorts.
Old 07-29-2006, 03:27 PM   #16
johnnyfive
johnnyfive's Avatar
can see all pics fine, and nice job on the write up ;)
cant wait for my springs to come in :)
oh, and maybe you should update your siggy, with the new lower yaris? :)
johnnyfive is offline
Old 07-29-2006, 03:27 PM   #17
SamDaYarisMan
SamDaYarisMan's Avatar
Drives: meteorite liftback
Great job chris, glad you did the how to instead of me. You didnt miss anything. Im also very happy with mine. Ride is just a tad stiffer but car corners a whole lot better. i didnt cut my bump stops and it hasnt bottomed out yet..knock on wood.
YARIS LIFTBACK: meteorite metallic, 5speed, debadged, 15" black rota gt-3's w/ 205/50/15's, tanabe df210's, colibri universal power window kit, glow shift 2" tach and twm shortshifter.
FUTURE MOD's: power door lock kit w/ keyless entry and new audio.
SamDaYarisMan is offline
Old 07-29-2006, 03:45 PM   #18
Chris07LB
Chris07LB's Avatar
I only cut mine, just because over the years every car i've lowered, said to.
I called Tanbe USA just to ask and be sure, and they said to cut them as well.
Tanabe Strut Tower Bar Install & Review [pics!] Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 04-07-2022 07:46 AM
Springs - Tanabe DF210 or Tein S Tech andylai2k Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 06-10-2007 09:22 PM
Tanabe DF & Strutbar install mcdaddy DIY / Maintenance / Service 18 05-03-2007 09:57 PM
TANABE DF210 SPRINGS AVAILABLE!!! C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 08-05-2006 12:28 AM
Spring Install Price redglare45 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-30-2006 08:32 PM
