Old 02-19-2009, 12:53 AM   #1
GeneralDon7
Drives: Yaris Sedan
Water Pump issue, after taking in for Recall
Ok, so today I took my 2007 Sedan, into get that recall seatbelt issue fixed, by the way, I havent noticed any difference in outside noice. I was told that my water pump was malfuctioning an they have to replace it, even though the car never showed me the check engine light, the toyota person told me, that it wasnt a big issue, so I scheduled it for 2 saturdays from now. Has anyone else had this issue?, its covered under warranty, so its a free fix either way, i was just curious how commmon this was. My car has 40000 and is 2 years old. Good thing I havent gotten the water pump pulley upgrade yet.
GeneralDon7 is offline   Reply With Quote
Old 02-19-2009, 07:09 AM   #2
SailDesign
Drives: .
I have a 2007 Hatchback, about 32000 miles on it, and no problem yet. i'll be curious to see what other folks have to say, though.
Old 02-19-2009, 07:35 AM   #3
YAR1S
YAR1S's Avatar
36k no problems?? :S
-Jen <3
Old 02-19-2009, 09:25 AM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
i had problems with both the alternator bearings and the water pump getting ceased up.
a little over 2 years old, and 56000km when both was changed.
Old 02-19-2009, 09:46 AM   #5
*MAD DOG*
*MAD DOG*'s Avatar
15,000km and no issue with water pump.
Old 02-19-2009, 12:44 PM   #6
Danish Yaris
Drives: Toyota Yaris 1,8 TS 5dr. 2007
Hi
If the water pump need replacing it won´t put a check light in the display. It will leak water and perhaps it´s not very much, but when it´s on the guarantee it doesn´t matter.
I work at Toyota and I think we have replaced only one on the guarantee on a Toyota Yaris.
Regards Steven.
Danish Yaris is offline   Reply With Quote
Old 02-19-2009, 01:07 PM   #7
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
same here.....
Old 02-19-2009, 02:35 PM   #8
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Water pump failure is not uncommonon the 2004-2006 Scion Xb's. If you check over on Scion life you will see it is actually quite common. In fact on my 2005 Xb with 59,000 mile is starting to show a little dried coolant "crust" under the weep hole, so mine is on it's way out too.
PS- Yaris and Xb have the same motor, though I'm not sure the water pump is identical...
Old 02-19-2009, 03:01 PM   #9
BLAZINBLUEVITZ
echo prius xa xb and yaris share same water pump....
Old 02-19-2009, 04:03 PM   #10
IllusionX
ah, i haven't had prob with my 05 echo with 60000km. (2 years old when i sold it)
Old 02-19-2009, 04:07 PM   #11
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Surprised they covered it. IIRC the water pump does not consist of the "powertrain", thus falling under the bumper-to-bumper warranty (which should have expired with that kind of mileage).
Old 02-19-2009, 04:11 PM   #12
BLAZINBLUEVITZ
extended warranty.........
Old 02-19-2009, 04:12 PM   #13
firemachine69
Ha, don't know too many folks who actually get those (as they are usually a rip-off).
Old 02-19-2009, 04:41 PM   #14
kou
Drives: 08 lb
on my last yaris the waterpump went bad with under 15ooo miles. http://www.yarisworld.com/forums/sho...=waterpump+diy
Old 01-17-2012, 12:18 PM   #15
Nova Scotia
My 2007 yaris hatchback has over 250,000 on it with all original parts minus the break pads/shoes, sparkplugs, oil filters and whatever they change during regular maintances...which we kept doing.
good little car.
Im thinking maybe the water pump is finally starting to go....a whiring sound from motor area...grindy. will check for water leaks
Nova Scotia is offline   Reply With Quote
Old 01-17-2012, 12:24 PM   #16
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
had mine replaced at 80k kms but it might have been leaking since 60k
Old 01-17-2012, 12:29 PM   #17
marcus
toyota
marcus's Avatar
easy to tell check the inside part of the pulley you should see pink stuff if its leaking..
good little car.
Old 01-17-2012, 02:29 PM   #18
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I'm not going to tell you it's been hundreds of thousands of miles with no problems, because I don't want to jinx myself. ;)
-Type 07 FFL-
My odometer 03/11
electric water pump help! mandriu Performance Modifications 39 10-24-2009 02:56 AM
bye bye water pump cali yaris Performance Modifications 29 01-03-2009 05:06 PM
