Old 06-09-2011, 10:25 AM   #1
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
Problem help
Hi friends. Disaster struck, I broken automatic transmission. For repairs requested $ 4k. How much you worth after selling a new or in good condition?
MickZEL is offline   Reply With Quote
Old 06-09-2011, 11:41 AM   #2
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I dont quite understand the question.
Are you asking how much is a new or used (in good condition) transmission?
or
How much is a Yaris worth new or used?
Old 06-09-2011, 12:18 PM   #3
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
Old 06-09-2011, 01:59 PM   #4
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I guess that depends on if you have a junkyard close by or not. I'd look there first.
-Type 07 FFL-
My odometer 03/11
Old 06-09-2011, 02:11 PM   #5
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
There's nothing that I want.
Yaris Sedan 2007-2008 recently were imported into Russia from the USA and Canada.
Old 06-09-2011, 02:17 PM   #6
ilikerice
ilikerice's Avatar
a new one is probably only found at the dealership. and your looking at a couple thousand for that.
but for a used one, you are taking a gamble if you havent seen the trans in the car and running prior to purchase. Used transmissions (auto) i see run from 200-1000 dollars depending on the seller, buyer and location
Old 06-10-2011, 07:27 AM   #7
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I guess the warranty has expired?.
Old 06-10-2011, 09:30 AM   #8
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
YES
Old 06-26-2011, 11:10 AM   #9
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
I want to thank CTScott for their help in my problem.
The person responded to my trouble. Found my transmission and sent to Russia.
This position deserves great respect. Once again, thank you Scott.
Old 06-26-2011, 02:22 PM   #10
Your very welcome! That was by far the most interesting parts shipment I have ever done.
Old 06-26-2011, 09:14 PM   #11
fj40dave
fj40dave's Avatar
Drives: '08 HB
Good Job Mr. Scott!
fj40dave is offline   Reply With Quote
Old 06-29-2011, 09:10 AM   #12
TOLMACH
Drives: soarer
Originally Posted by fj40dave View Post
Good Job Mr. Scott!
+1
Old 06-29-2011, 11:17 AM   #13
Kiteless
Kiteless's Avatar
Drives: US 2007 Yaris Liftback 5MT
Can I ask how much was saved? How much did you find a (used?) Auto Trans for? I am just curious, and kudos for hooking up this guy!
- Jason
2007 Toyota Yaris Liftback Base 5 Speed.
Mods: Netz/Vitz/RS badging, RS style spoiler, RS replica tails, Tenabe NT210 Springs, Tokico Blue Struts, Team Dynamics 14", fogs(Arrived), JDM HKS Exhaust.
Kiteless is offline   Reply With Quote
Old 06-29-2011, 12:44 PM   #14
- Jason
The transmission was off of a 2008 that only had 3,800 miles on it before the owner decided to try to pass a trailer truck by going under it. The car only had damage from the top edge of the hood and up, so the drivetrain was perfect. I have actually purchased a lot of parts off of the car, and even saw it running before the junkyard pulled the engine and tranny to put them on the shelf.
The junkyard charged me $600 + sales tax, so I loaded it into my Xterra for $636. You can often pick them up for far less on eBay (as cheap as $250), but not with such low miles.
I was originally going to ship it via UPS Freight and even spoke to UPS to get a quote and verify some things regarding the create. UPS quoted me a little over $500 to ship it. I had it crated and was ready to bring it to the UPS Freight depot and called them one more time to verify which airport in Moscow Mikhail would need to pick it up from. At that time UPS told me that due to Russian customs issues, they can not ship a freight item to an individual. It would have to go to a business and that business would have to do tons of paperwork to get it out of customs.
So, thinking that we were dead in the water, I called USPS for the heck of it to see if I disassembled it into 70 lb parcels (the max weight for USPS) if they would ship it. The answer was not just "Yes", but that USPS has less issues delivering to individuals in Russia than they do to people in Italy or Spain.
So, out of the crate it came. I then proceeded to disassemble it, literally on a freight scale, working towards getting the main body of the transmission to be less than 65 lbs, so that it plus packaging would equal less than 70 lbs.
I ended up with three boxes.
Box 1 of 3 - 66 lbs.
1. Toyota Yaris U340 Transmission Case
Box 2 of 3 - 36 lbs.
1. Differential
2. Oil Pump
3. Input Shaft/Forward Clutch Hub Assy.
4. Oil Strainer Assy. w/screws
5. AT Oil Pan Assy. w/screws
6. Manual Detent Spring Assy. w/screws
7. Transmission Wire
8. Speedometer Sensor
9. Accumulator Pistons x3
10. Check Ball Assy.
11. Gaskets x4
12. Bell Housing Bolts x11
13. Oil Pump Bolts x7
Box 3 of 3 - 52 lbs.
1. Bell Housing
2. Torque Converter
3. Valve Body
I took pictures of every step of the disassembly process and provided Mikhail with the attached detailed document on how to reassemble it. I learned a lot during the process and now am completely ready to install a limited slip differential in Crashy's automatic transmission.
Toyota Yaris U340 Automatic Transaxle Assembly.pdf
Old 06-29-2011, 02:01 PM   #15
mazilla
advocatus diaboli
mazilla's Avatar
Whoa! You're the man CT, that was exceptional of you to go through so much trouble. Kudos
-Type 07 FFL-
My odometer 03/11
Old 06-29-2011, 02:29 PM   #16
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
Yes. And now all the transmission in my home.
Old 06-29-2011, 03:21 PM   #17
Kiteless
Kiteless's Avatar
The transmission was off of a 2008 that only had 3,800 miles on it .........
Wooooow man! That is amazing and really nice of you to go through the hassle of doing all that for a far off Yaris owner. You Dah Man!
- Jason
Old 06-29-2011, 05:22 PM   #18
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
yup, hats off to you CTScott, that's pretty incredible to go through all that trouble.
goliath1812 is offline   Reply With Quote
Problem with my car rakhan01 DIY / Maintenance / Service 8 12-03-2010 05:12 AM
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 01:30 AM
Problem Starting Car drunkwithwords General Yaris / Vitz Discussion 3 07-21-2010 04:01 PM
Yaris Central Locking Problem pbasuita UK 0 07-10-2010 03:46 AM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
