Old 06-20-2012, 12:02 AM   #1
2012 YarisSE
Drives: NCP131
Toyota emblem on 2012 Yaris
How to remove the FRONT stock Toyota emblem I'm trying to switch to Vitz is it the same way as the old gens?
2012 YarisSE is offline   Reply With Quote
Old 06-20-2012, 12:06 AM   #2
Klink10
Klink10's Avatar
can I assume you are referring to the front?
Old 06-20-2012, 12:49 PM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
odds are it is identical to the other gens, yes.http://www.yarisworld.com/forums/sho...e+front+emblem
Colin Chapman disciple
Old 06-20-2012, 02:37 PM   #4
CPALK719
CPALK719's Avatar
Drives: 2012 toyota yaris
the front is probably held in by some sort of tabs or little teeth that help keep it in place. Just be careful when you pry it off, you don't want to break any of the small teeth/tabs on the back of the emblem. as for the rear simply use some fishing line.
2012 yaris L model
2014 wrangler unlimited sport
CPALK719 is offline   Reply With Quote
Old 06-20-2012, 07:10 PM   #5
And just so you can explain it properly when asked what it is, that is a Netz badge you are putting on, not a Vitz.
Old 08-16-2012, 09:23 PM   #6
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
BUMP! the front "t" badge on the 2012 yaris is deeper by about 3/4 of an inch and the material angles up slightly from front to back of emblem.....waiting patiently for a Netz equivalent.....
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Toyota Yaris HSD Concept - Preview of the upcoming Yaris Hybrid (teaser pic) Kal-El Third Gen Yaris General Discussion 37 06-25-2011 06:16 AM
